Change sheet metal rule in sheet metal defaults using API
nishantkumat5921
nishantkumat5921
I am trying to change the sheet metal rules mentioned in sheet metal defaults but could find any API codes in the forums so reaching out for help. For example I want to change it from "14 GUAGE C.R.S" to "14 GUAGE 304S.S ". I do not want help in illogic's but need help in API.
Thanks in advance. Attaching a image below for clarification on what ISheet_Metal.PNG want to change.
bradeneuropeArthur
Dim a As Inventor.PartDocument = ThisDoc.ModelDocument
Dim c As Inventor.SheetMetalComponentDefinition = a.ComponentDefinition
c.SheetMetalStyles.Item("14 GUAGE 304S.S").Activate
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
FINET_Laurent
You can use :
Dim oSheetMetal As SheetMetalComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
oSheetMetal.SheetMetalStyles.Item("Par Défaut").Activate
In your case :
oSheetMetal.SheetMetalStyles.Item("14 GUAGE 304S.S").Activate
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
nishantkumat5921
Thanks @bradeneuropeArthur for the quick reply and found the solution.
