Change part colour in drawing with ilogic
Message 1 of 15
Is it possible to paint (change colour) of some parts in a drawing using ilogic?
I have a drawing of an assembly, where are many elements.
I would like to automatically paint parts in specific colour (type of colour doesn't matter, can be red, green etc.).
When I paint "Element1" to red, I want all occurrences of "Element1" to be painted (since there are many) and on all views. This is important to me because number of occurrences changes.
How can I do it with ilogic?
Replies (14)
Message 2 of 15
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that below forum discussion link may be helpful.
https://forums.autodesk.com/t5/inventor-forum/update-drawing-line-colour-based-on-part-colour/td-p/7...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 15
Discussion from the link is about getting colour from the part and puting it to drawing.
In my case it is impossibile, because many different parts have the same colour (it is connected with material).
I would like to paint a specific part (all occurrences of this part) with some colour (for example red) with no connection to part colour.
Message 4 of 15
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please provide sample assembly with drawing to test? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 15
Ok I put a sample assembly with drawing.
Drawing has 2 sheets. First is balck and white. The second is coloured manually.
Message 6 of 15
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to color parts in assembly. In this example, there are 3 parts in assembly. So, code works for 3 colors only. It extended for different colors based on situations.
Sub Main()
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    Dim layers As LayersEnumerator
    layers = oDoc.StylesManager.Layers
    On Error Resume Next
    Dim oRed As Layer
    oRed = layers.Item("Red")
    If Err.Number <> 0 Then
        On Error GoTo 0
        Dim redColor As Color
        redColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
        ' Copy an arbitrary layer giving it the name
        ' of the render style.
        oRed = layers.Item(1).Copy("Red")
        ' the attributes of the layer to use the color,
        ' have a solid line type, and a specific width.
        oRed.Color = redColor
        oRed.LineType = kContinuousLineType
        oRed.LineWeight = 0.02
     End If
    Dim oGreen As Layer
    oGreen = layers.Item("Green")
        On Error GoTo 0
        Dim greenColor As Color
        greenColor = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
        oGreen = layers.Item(1).Copy("Green")
        oGreen.Color = greenColor
        oGreen.LineType = kContinuousLineType
        oGreen.LineWeight = 0.02
     End If
    Dim oBlue As Layer
    oBlue = layers.Item("Blue")
        On Error GoTo 0
        Dim blueColor As Color
        blueColor = ThisApplication.TransientObjects.CreateColor(0, 0, 255)
        oBlue = layers.Item(1).Copy("Blue")
        oBlue.Color = blueColor
        oBlue.LineType = kContinuousLineType
        oBlue.LineWeight = 0.02
     End If
     Dim colorColl As ObjectCollection
     colorColl = ThisApplication.TransientObjects.CreateObjectCollection
     Call colorColl.Add(oRed)
     Call colorColl.Add(oBlue)
     Call colorColl.Add(oGreen)
    Dim oView As DrawingView
    For Each oView In oSheet.DrawingViews
        Dim oReferDoc As AssemblyDocument
        oReferDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim oAssyDef As AssemblyComponentDefinition
        oAssyDef = oReferDoc.ComponentDefinition
        Dim occDoc As Document
        Dim cnt As Integer
        cnt = 1
        For Each occDoc In oReferDoc.AllReferencedDocuments
            Dim occ As ComponentOccurrence
            For Each occ In oAssyDef.Occurrences
                If occ.ReferencedDocumentDescriptor.ReferencedDocument Is occDoc Then
                    Dim oCurves As DrawingCurvesEnumerator
                    oCurves = oView.DrawingCurves(occ)
                    Dim oCurve As DrawingCurve
                    For Each oCurve In oCurves
                        Dim oColl As ObjectCollection
                        oColl = ThisApplication.TransientObjects.CreateObjectCollection
                        Dim oSegment As DrawingCurveSegment
                        For Each oSegment In oCurve.Segments
                            Call oColl.Add(oSegment)
                        Next
                        Call oSheet.ChangeLayer(oColl, colorColl.Item(cnt))
                        Call oDoc.Update
                    Next
                End If
            Next
            cnt = cnt + 1
        Next
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 15
It works exactly as You said - three different parts become coloured in three different colours.
But what if I would like to call a specific part by name in order to paint it? For example:
Colour "Element 01" to red (all occurrences).
Colour "Element 02" to green (all occurrences).
Do not colour "Element 03" (not all parts need to be coloured)
Colour "Element 04" to blue (if exists)
This is because number of different elements will change (there may be "Element 04", "Element 05" , "Element 03" may disappear, etc.)
Message 8 of 15
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try this.
Sub Main()
    Dim oSheet As Sheet
    Dim oRed As Layer
        On Error GoTo 0
     End If
    Dim oGreen As Layer
        On Error GoTo 0
     End If
    Dim oBlue As Layer
        On Error GoTo 0
     End If
	            Next
				Dim occName As String
				occName = occ.Name
				If occName.StartsWith("Element 01") = True Then
					Call oSheet.ChangeLayer(oColl, oRed)
				Else If occName.StartsWith("Element 02") = True Then
					Call oSheet.ChangeLayer(oColl, oGreen)
				Else If occName.StartsWith("Element 04") = True Then
					Call oSheet.ChangeLayer(oColl, oBlue)
				End If
	            Call oDoc.Update
	        Next
    	Next
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 15
RoyWickrama_RWEI
I am interested in assigning color to a layer in the drawing:
Color: Dark Brown
I am trying to assign colot to Dark Brown without success. Please help. Thanks.
Sub Main()
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    Dim oLayer As Layer
    ' oLayer = oDrawDoc.StylesManager.Layers.Item(68)
    oLayer = oDrawDoc.StylesManager.Layers.Item("Title (ISO)")
    Dim oNewLayer As Layer
    oNewLayer_Name = "XYZ"
    Try
    oNewLayer = oLayer.Copy(oNewLayer_Name)
    Catch
    MessageBox.Show("New layer, " & oNewLayer_Name & ": Exists", "Title")
    End Try
ThisDrawing.Document.StylesManager.Layers(oNewLayer_Name).Visible = False
ThisDrawing.Document.StylesManager.Layers(oNewLayer_Name).Plot = False
End Sub
Need help to assign
Message 10 of 15
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Hoping that below iLogic code may be helpful.
Sub Main()
    Dim oLayer As Layer
    Try
    Catch
    End Try
	Dim brownColor As Color
	brownColor = ThisApplication.TransientObjects.CreateColor(165, 42, 42)
	oNewLayer.Color = brownColor
	oNewLayer.LineType = kContinuousLineType
	oNewLayer.LineWeight = 0.02
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 15
RoyWickrama_RWEI
Hi Chandra Shekar;
Thanks a lot for the great help. It is fine. Also, I tailored the rule (see the attached .txt file).
brownColor_1 = ThisApplication.TransientObjects.CreateColor(xxx, xxx, xxx)
brownColor_2 = ThisApplication.TransientObjects.CreateColor(xxx, xxx, xxx)
Could you provide me with the coding for brownColor_1  andbrownColor_2: see the image below.
Could I know the list of TransientObjects.CreateColor for all colors.
Thanks again.
Message 12 of 15
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Refer below images to get RGB values for brown color.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 15
RoyWickrama_RWEI
Thanks a lot for the help.
That is fine.
I am taking sometime off from Inventor customization training (from today till end of Sept) for taking some strenuous self faced training in using SolidWorks 2019.
Planning to take very high skills in Solidworks as well.
Message 14 of 15
anthony.ravello
Hello
How do you change the colour of a iPart in Drawing?
That is very importante for me 🙂
Message 15 of 15
anthony.ravello
very interesting
is it Posible to change the colour of the Parts in Drawing using custom Properties?
I mean. Some parts have the same custom Property called "Green". Then in Drawing change all this parts in this color (preferably to have a layer with this name "Green" too)
