Change Icon of Client Feature via API
Hi everyone,
I've created a Client Feature containing tons of other Features, so far so good.
Now, I have this Client Feature, with a Client Feature name, but only with the standard Client Feature Icon (<x> with a blue square body).
I want to change this icon to something more specific 🙂
The resources I found on the internet are not working (don't know why).
(https://adndevblog.typepad.com/manufacturing/2015/01/change-icon-of-clientfeature-node-in-built-in-b...)
(https://adndevblog.typepad.com/manufacturing/2012/08/change-the-browser-node-icon.html)
I got multiple exceptions if I try.
So, has someone a simple example? (Override Icon etc.)
This is the current status:
Greetings to all.
etaCAD
here are some parts of my code to change the icon of the client feature. This works only as add-in.
 ' Try to find an existing resource.
                Dim oCnr As ClientNodeResource = Nothing
                Dim oCheckResource As ClientNodeResource
                For Each oCheckResource In mPartDocument.BrowserPanes.ClientNodeResources
                    If oCheckResource.ClientId = "FeatureClientID" Then
                        ' Save a reference to the existing client node resource.
                        oCnr = oCheckResource
                        Exit For
                    End If
                Next
                ' Create the resource if it doesn't already exist.
                If oCnr Is Nothing Then
                    Dim oIcon As IPictureDisp
                    oIcon = mBrowserIcons.RBfeatureBrowser  ' Das geht nur als Addin
                   ' Create a client node resource.
                    oCnr = mPartDocument.BrowserPanes.ClientNodeResources.Add("FeatureClientID", -1, oIcon)
                End If
' Get the browser node definition associated with the client feature.
Dim oNativeBrowserNodeDef As NativeBrowserNodeDefinition
oNativeBrowserNodeDef = mPartDocument.BrowserPanes.GetNativeBrowserNodeDefinition(oClientFeature)
' Override the icon for the client feature.
oNativeBrowserNodeDef.OverrideIcon = oCnr
Andreas
etaCAD
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Hoping that suggestions in the below link may be helpful.
https://blogs.msdn.microsoft.com/andreww/2007/07/30/converting-between-ipicturedisp-and-system-drawing-image
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Passi10
Hi Andreas,
first of all, thanks for your reply.
This line here:
Creates an exception. The problem is, the exception is not very specific 🙂
What I know is: I took the correct Feature Client ID
The oIcon is only the picture data. I also got that correctly.
So, there are only 2 possibilities existing:
1. The Id Integer is not correct (-1)
2. The line is not working here because of a reason I didn't know. (Write protection of the specific Clientnoderesources?!?!
I have nooo idea.
(By the way, this line was also the reason, I didn't get the other examples working.)
Greetings
