Error when save a file
SandmanINV
SandmanINV
At the end of part, i often use "oinv.activedocument.save(.......,False)" to saving a file (ipt or iam).
oinv is a variable of inventor.application.
It often save successfully, but, sometime, my programe meet error when debug to this line.
If i try turn off inventor and start again, it save successfully.
So I dont know what wrong with them, how to fix this ?
Please give me some advices ?
Thank you,
Sergio.D.Suárez
Hi, I would try thisDoc, to set the document, not ActiveDocument, sometimes it creates conflicts when you are in a document and the rule should save another document, but the active document is the first one, instead thisDoc specifies that it is that document in particular where the rule is located
Dim doc = ThisDoc.Document
doc.Save
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
SandmanINV
Thank you for your advice, I am using vb.net. So i dont find "Thisdocument" in VB.net.
So I using this code flollow your advice.
        Dim osave_file As Document
        osave_file.SaveAs(ofilename_asm_xuongdam, False)
But it still error. Maybe I still wrong some where...
GeorgK
Dim m_inventorApplication As Inventor.Application = Nothing
m_inventorApplication = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
Dim oDoc As Document
oDoc = m_inventorApplication.ActiveDocument
oDoc.SaveAs("C:\Temp\TestFile.ipt", True)
https://adndevblog.typepad.com/manufacturing/2012/12/saveas-with-savecopyas-false.html
