Change hole type
Change hole type
sanderlaska
Change hole type
sanderlaska
Hello my friends from this amazing forum,
I have the next thing i want to do,
Save the assembly,
save it as a copy
check the assembly for all holes
Select all countersink holes
change them to a normal holes.
would this be possible?
WCrihfield
Hi @sanderlaska.  It sounds possible.  After saving the assembly as a copy, would you want the code to continue to work with the original assembly, or the newly created copy of the assembly?  Were all the holes made with a HoleFeature, or were they created by extruded cut features?  Were all the holes you want to target created directly within the main assembly, or are some or all of them created down within parts or sub-assemblies?  If any of the holes are pattered, then were they patterned by sketched points for centers, or by using regular feature pattern creation tool?
Wesley Crihfield
(Not an Autodesk Employee)
