How can I mount ipt files in iam file via Inverntor api?
hayattangercekler2
hayattangercekler2
How can I add ipt to an iam file that I open with the Inventor api? Then I need to assemble them from the points whose coordinates are given correctly. How can I do these?
A.Acheson
Hi @hayattangercekler2
Have you checked out the API samples written in VBA/C#?
Here are links for adding part occurrence
and creation an insert constraint.
I see a very similar post here.
It is best to stick with the same post and just ask more questions or post some sample codes you would like to trouble shoot.
Regards
Alan
