Change Content Center Type
DewayneH
Message 1 of 10
DewayneH
We have had several issues with users copying "standard" content center files to a custom location instead of placing as custom. The file is then customized with features.
The problem being, the file is recognized as a "Standard" content center file from that point on. This causes a multitude of issues for us.
It is not possible to replace from the Content Center and simply change to "Custom" without loosing all the features.
I have found code that checks for the "Content Center Type" and some can strip the information to convert to a normal part. I'd like to maintain the association to the content center for size change purposes.
Is it possible to change the "Content Center Type", from "Standard" to "Custom"?
Dewayne
Inventor Pro 2023
Vault Pro 2023
Replies (9)
Message 2 of 10
bradeneuropeArthur
You can change the property Content Center to false. Then it is seen as a custom CC part.
Is this what you need?
I can help you with a piece off code if you want.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
bradeneuropeArthur
Related to this idea:
https://forums.autodesk.com/t5/vault-ideas/contentcenter-propertyset-and-property-iscustompart/idi-p...
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 10
DewayneH
So it can be changed, great.
Now to figure it out. Looked at it a little but no progress yet.
Dewayne
Inventor Pro 2023
Vault Pro 2023
Message 5 of 10
bradeneuropeArthur
I can help you with a piece of code, if you want.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 10
DewayneH
Sure. Do you have an example?
Dewayne
Inventor Pro 2023
Vault Pro 2023
Message 7 of 10
bradeneuropeArthur
Today?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
DewayneH
No. It isn't pressing by any means.
The situation has popped up several times. Fortunately the changes to the parts were minor, so we were able to redo the parts.
This latest one was a little more complicated. It got me to thinking of implementing a solution should it happen again.
Dewayne
Inventor Pro 2023
Vault Pro 2023
Message 9 of 10
bradeneuropeArthur
Would it be a good idea to put all the related Content Center files in one assembly and run a piece of code to change the Property to false?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
bradeneuropeArthur
Dim a As AssemblyDocument = ThisAssembly.Document
Dim p As PartDocument
For Each p In a.ReferencedDocuments
	Dim pr As Inventor.Property
	For Each ps As PropertySet In p.PropertySets
		Try
			If ps.Item("ContentCenter").Name = "ContentCenter"
			ps.value= 0
		Catch
		End Try
	Next
	Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
