Change Component Color to RGB Value
mk92
mk92
is it possible to change the Component color to an RGB value?
Instead of:
Component.Color("Part_1:1") = "Cyan"
Like (255,255,0) or anything.
If found this thread:
Link to Inventor Forum
But in hope there is an easier way without any subs and so on.
Kind regards.
MechMachineMan
Don't think so.
The appearances are set using appearance assets, so unless the method automatically created it, you are SOL.
You can make the sub do all the work and just call it with 1 line (and associated arguments) in your main code body though... Just need to place the sub somewhere in the same rule.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
