change color of drawing sheet
Message 1 of 8
I have to change the color of the sheet inside a drawing file from default to white.
How can I do that?
I have to do that by a macro, but I cannot find the property that changes the color of the sheet.
Replies (7)
Message 2 of 8
Open the IDW file and then go to "Tools" > "Document Settings..." in the menu. then select the "Sheet " tab and change the color swatch for "Sheet" to white. Do this in your template file to have the same in all new drawings. -- Phil Kenewell ---------------------- Gage Designer North American Lighting, Inc. "fnatali" wrote in message news:30830972.1103288110183.JavaMail.jive@jiveforum1.autodesk.com... > I have to change the color of the sheet inside a drawing file from default to white. > How can I do that? > I have to do that by a macro, but I cannot find the property that changes the color of the sheet.
Message 3 of 8
This I know but I'd like to change the color by a macro....my aid is to do a macro which automatically switches the color from default to white,then saves the file and switches the color to default again.
But I cannot find the property in VBA that is connected to the color of the sheet
Message 4 of 8
"fnatali" a écrit dans le message de news:15571712.1103529164383.JavaMail.jive@jiveforum2.autodesk.com... > This I know but I'd like to change the color by a macro....my aid is to do a macro which automatically switches the color from default to white,then saves the file and switches the color to default again. > But I cannot find the property in VBA that is connected to the color of the sheet I'm facing a similar problem i think. I'd like to change the color of a drawing view ( an assembly or a part of an assembly in a drawing view in fact ) but i can't figure out where to find this kind of properties in the DrawingView object This might no be available yet, since DrawingView are quite new features in the API ... . nicolas
Message 5 of 8
Nobody answered me!!!!
Please someone give me an answer!!!!!!!!!!!!
Message 6 of 8
I've been looking for this too...so far no luck.
Message 7 of 8
The API supports the setting the sheet color in R11. Note, however, that
this is controlled via a document setting and hence the color change applies
to all sheets in the document. Here is a sample (will work R11 onwards):
Sub SheetColor()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheetSettings As SheetSettings
Set oSheetSettings = oDoc.SheetSettings
Dim oColor As Color
Set oColor = ThisApplication.TransientObjects.CreateColor(200, 200, 200)
oSheetSettings.SheetColor = oColor
End Sub
Sanjay-
wrote in message news:5251137@discussion.autodesk.com...
Message 8 of 8
jwoutersJC4LN
Hi there,
is there a way to change the code so the color can also be set back to the origin?
for example;
my sheet is yellow, set them to white and by pusing again, back to yellow?
regards,
Justin
