Pipe runs
Pipe runs
Pipe runs
Can we create 3D sketches for pipe runs etc. - using the API yet?
Should be able to. AIP (piping and routing) is built using the Inventor API. -- Sean Dotson, PE www.sdotson.com www.mcadforums.com Autodesk Inventor Certified Expert "envisage" wrote in message news:31714528.1103217406614.JavaMail.jive@jiveforum1.autodesk.com... > Can we create 3D sketches for pipe runs etc. - using the API yet?
If you are asking about creating workpoints and 3DSketches, I think the answer is yes. If you want to drive the creation of AIP piping runs, I would venture it is impossible or difficult at best. AIP piping uses a lot of database access and would be very difficult to work with. envisage wrote: >Can we create 3D sketches for pipe runs etc. - using the API yet? > >
