Change Application Options Color Scheme, And Visual Style for clear printing.
C_Haines_ENG
C_Haines_ENG
Id like to be able to change the color sceme to have a white background, and change the visual style to "Wireframe with hidden edges", after this it would print and change everything back.
Is this possible? It would be inside part / assembly files.
earl_cody
@C_Haines_ENG - Hi. Try this ilogic.
iLogicVb.UpdateWhenDone = True
'get active Inventor application
Dim inv As Inventor.Application = ThisApplication
'create handles to original settings (to set back to at end)
Dim colorSchemeOriginal As Inventor.ColorScheme = inv.ActiveColorScheme
Dim colorSchemeBackgroundTypeOriginal As Inventor.BackgroundTypeEnum = inv.ColorSchemes.BackgroundType
Dim viewDisplayModeOriginal As Inventor.DisplayModeEnum = inv.ActiveView.DisplayMode
'change to white background with wireframe with hidden edges
Call inv.ColorSchemes.Item("Presentation").Activate()
inv.ColorSchemes.BackgroundType = Inventor.BackgroundTypeEnum.kOneColorBackgroundType
inv.ActiveView.DisplayMode = Inventor.DisplayModeEnum.kWireframeWithHiddenEdgesRendering
'update the active view
Call inv.ActiveView.Update()
'get handle of active document
Dim doc As Inventor.Document = inv.ActiveDocument
'get handle for print manager
Dim printMGR As Inventor.PrintManager = doc.PrintManager
'set settings for print manager
printMGR.Printer = "Microsoft Print to PDF"
'commented out the following settings for user to decide
'printMGR.PaperSize = Inventor.PaperSizeEnum.kPaperSizeLetter
'printMGR.Orientation = Inventor.PageOrientationTypeEnum.kLandscapePageOrientation
'printMGR.ColorMode = Inventor.PrintColorModeEnum.kPrintGrayScale
'create string filepath of exported PDF file
Dim fpPDF As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop) & "\" & doc.DisplayName.Split(".")(0) & ".pdf"
'print
Call printMGR.PrintToFile(fpPDF)
'change the environment back to original settings
Call colorSchemeOriginal.Activate()
inv.ColorSchemes.BackgroundType = colorSchemeBackgroundTypeOriginal
inv.ActiveView.DisplayMode = viewDisplayModeOriginal
'update active view
MessageBox.Show("Done")
C_Haines_ENG
Absolutely amazing! Thank you!
