Code worked in 2022 but not in 2023
AMN3161
AMN3161
So my company has been using this code I made to automatically pull BOM information, it been working great for years and since we got the 2023 it is some what buggy. This is just a portion of the rule, no point of posting the entire rule. This error can be created when i run this isolated from the but it requires you to have a custom iproperty called "Project_ Excel_File_Name" already created.
If iProperties.Value("Custom", "Project_ Excel_File_Name") = "" Then
MessageBox.Show("I dont have a project Excel BOM linked, please show me where it is", "Project BOM", MessageBoxButtons.OK)
Dim oFileDlg1A As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg1A)
oFileDlg1A.InitialDirectory = oOrigRefName1A
oFileDlg1A.CancelError = True
On Error Resume Next
oFileDlg1A.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg1A.FileName <> "" Then
selectedfile1A = oFileDlg1A.FileName
MessageBox.Show("You selected: " & selectedfile1A, "iLogic")
iProperties.Value("Custom", "Project_ Excel_File_Name") = selectedfile1A
End IF
Previously, it would pop open a window and i can select a file but now the window only shows folders not  any of the contained files of any file type
Is this a Inventor bug or is the code not operation the same in the new inventor?
A.Acheson
Maybe the application object  should be "ThisApplication".  This is the sample file dialog I would use.
Regards
Alan
whashtonjrGV2BR
@A.Acheson
The reference you are pointing to is for VBA, not iLogic (VB.Net based) which is what AMN3161 is referencing. I sometimes catch myself doing that.
Unfortunately, I'm stuck in the past (2018) waiting for my company to get up to speed.
@AMN3161
However, when I first ran the code, I could select a file (so the folder only view wasn't an issue) but nothing would happen when I selected OK. I added a file type filter (oFileDlg1A.Filter = "Excel Files (*.xls;*.xlsx)|*.xls;*.xlsx") and tried it again and it worked correctly. So likely a different bug in 2018 but worth a try?
Add it after the CreateFileDialog.
oFileDlg1A.InitialDirectory = ThisDoc.Path
Also check to be sure the VB.Net is current.
Hope this helps!
AMN3161
This fixed my problem, thank you!
A.Acheson
You are correct. I don't use VBA but because Inventor samples are written in VBA and not VB.NET we unfortunately have to keep referencing the samples we have. Once you know the small differences between the languages it makes writing VB.NET code very easy. One for the idea board I suppose.
Regards
Alan
