Change ActiveMaterial back to "Generic" programmatically
jefries1683
Message 1 of 11
jefries1683
I have already created a command which sets all objects within a selection to a chosen material.  It works as I hoped.
Now I am trying to create a command which reverts the objects of a selection back to the 'Generic' material and I cannot seem to get it working.
In both instances I cycle through all the available materials looking for a specific one, but 'Generic' is not found.
Public Sub ScrubKnData()
        Dim thisDocument As Document = g_inventorApplication.ActiveDocument
                For Each obj As Object In thisDocument.SelectSet
                    Dim thisMaterialName As String = "Generic Material"
                    Dim thisCompOcc As ComponentOccurrence = obj
                    thisDocument = thisCompOcc.Definition.Document
                    Select Case thisDocument.DocumentType
                        Case DocumentTypeEnum.kPartDocumentObject
                            Dim thisPartDoc As PartDocument = thisCompOcc.Definition.Document
                            Dim theseAssets As AssetsEnumerator = g_inventorApplication.ActiveMaterialLibrary.MaterialAssets
                            For Each thisAsset As Asset In theseAssets
                                If thisAsset.DisplayName = thisMaterialName Then
                                    thisPartDoc.ActiveMaterial = thisAsset
                                    thisDocument.Update()
                                    Exit For
                            Next
                    End Select
                Next
    End Sub
Any help would be appreciated.
Jeff
Replies (10)
Message 2 of 11
HermJan.Otterman
What happens if you try this manualy?
does the appearance then come from the library or from the part it self?
what is the error that you get?
can the material be found at all?
the string should be "Generic" ... not "Generic material"
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 3 of 11
jefries1683
Thank you for your reply.
Manually there is no problem.
The appearances work as expected when manual.
I can programmatically change the material from "Generic" to any other material, but not back to "Generic".
When I step through the code I observe that it finds 49 out of the 50 materials in the current library.  Generic is the missing material.  My assumption is that there is a specific way to change it to "Generic" similar to "ByLayer" in AutoCAD, but I can't seem to figure it out.
There is no error.  If the desired material is not found it does not attempt to change it.
I tried "Generic material" out of desperation when I was able to find a material with that name in another library type.  It didn't help and I simply forgot to change it back before I clipped the code here.  I am typically looking for "Generic" only.
Thank you,
Jeff
Message 4 of 11
HermJan.Otterman
Oke Jefries,
I made this code and it work with me.
I made it in VB.net, I think you are also using VB...??
So, have an Assembly open with parts in it.
select some parts and start this programm
it wil look in the part to see if the material asset is already local, if not it copies it from the library to local.
then it will set the local asset active.
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
ChangeMaterial("Generic")
End Sub
Private Sub ChangeMaterial(ByVal MaterialName As String)
'current doc = assembly, with parts selected
Dim oAssyDoc As AssemblyDocument = _inventorApplication.ActiveDocument
Dim oSelectSet As SelectSet = oAssyDoc.SelectSet
Dim oOccurrence As ComponentOccurrence = Nothing
Dim oPartDoc As PartDocument = Nothing
For Each oOccurrence In oSelectSet
oPartDoc = oOccurrence.Definition.Document
If oOccurrence.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oAsset As Asset = GetMaterialAssetLocal(oOccurrence.Definition.Document, MaterialName)
oPartDoc.ActiveMaterial = oAsset
Next
End Sub
Private Function GetMaterialAssetLocal(ByVal oPartDoc As PartDocument, ByVal Material As String) As Asset
' check if material already is local
Dim localAsset As Asset = Nothing
Dim oMaterial As Asset
For Each oMaterial In oPartDoc.MaterialAssets
If oMaterial.DisplayName = Material Then
localAsset = oMaterial
Return localAsset
Next
' this is from the Inventor API HELP
' Get an asset library by name. Either the displayed name (which
' can changed based on the current language) or the internal name
' (which is always the same) can be used.
Dim assetLib As AssetLibrary = Nothing
assetLib = _inventorApplication.AssetLibraries.Item("Autodesk Material Library")
'Set assetLib = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9")
' Get an asset in the library. Again, either the displayed name or the internal
' name can be used.
Dim libAsset As Asset = Nothing
libAsset = assetLib.MaterialAssets.Item(Material)
'Set libAsset = assetLib.AppearanceAssets.Item("ACADGen-082")
' Copy the asset locally.
Try
localAsset = libAsset.CopyTo(oPartDoc)
Catch ex As Exception
End Try
Return localAsset
End Function
Herm Jan
Message 5 of 11
jefries1683
That did it.  Thank you.
Can you help teach a man to fish?  I have the Inventor SDK, but I do not know of an 'API help' which you mention in your code.  Where can I find that?
Jeff
Message 6 of 11
MechMachineMan
@jefries1683 check out the links in my signature.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 7 of 11
HermJan.Otterman
Go to Inventor,
click the down arrow next to the "?" Upper right, go to Help,  than Programming/Api Help
Herm Jan
Message 8 of 11
jefries1683
Huh, look at that.  Right under my nose.
Thanks again to you and MechMachineMan,
Jeff
Message 9 of 11
bernd.schreck
@HermJan.Otterman Hi, I know this is an older discussion but I´m currently not able to proceed.
I´m programming an Add-in for Inventor (2020) using VB.NET.
I used  exactly your code and when the ActiveMaterial should be set (line: oPartDoc.ActiveMaterial = oAsset), I get the following error:
System.Runtime.InteropServices.COMException: 'Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))'
Does not matter if the material is in the local Asset or not.
Do you have a idea what triggers this error and why I can not set the active material of the part?
Message 10 of 11
HermJan.Otterman
Hello Bernd,
always difficult these kind of errors. do you use the right .net version? for 2020 this should be 4.7.
are you sure you are in a part document?
can this document be changed? (or is it maybe readonly?)
is the oAsset not nothing?
after that I have to see what is happening, by seeing the code or what you do
in that case, send me a private message.
Herm Jan
Message 11 of 11
bernd.schreck
Hello Herm Jan,
sorry that I reply that late, was on "vacation".
The .net version is 4.7.2
I using Vault (2020 Pro) and the file is Checked-out (but also does not work on non-Vault files).
I use the following code to call a helper function which gives me the materialasset (see below). The error is at line 3.
Even if the current material is the same as the selected one (in the code it is hard coded), I get the error. It seems that something internal is slightly different between the objects.
Private Sub ButtonSave_Click(sender As Object, e As EventArgs) Handles ButtonSave.Click
oDoc.ActiveMaterial = GetMaterialAssetLocal(oDoc, "POM")
oDoc.Update()
oDoc.Save()
Me.DialogResult =
System.Windows.Forms.DialogResult.OK
Me.Close()
End Sub
The helper function looks if the current asset is the wished material and if it is stored locally (in the file). Otherwise it copies it to it. I use a custom library, maybe this is the problem?
Private Function GetMaterialAssetLocal(ByVal oPartDoc As PartDocument, ByVal Material As String) As MaterialAsset
Dim localAsset As MaterialAsset = Nothing
Dim oMaterial As MaterialAsset
Return localAsset
Next
assetLib = invApp.AssetLibraries.Item("CommonMaterials")
' name can be used.
Try
End Try
Return localAsset
End Function
