Chamfer to all edge on selected body
kresh.bell
Message 1 of 14
kresh.bell
is it possible create iLogic for add chamfer to all edge on selected body?
Replies (13)
Message 2 of 14
Michael.Navara
This is the easiest way. This code adds chamfer to all edges, but be careful because you can't run it twice on body or it fails when the chamfer on some edge can't be created.
Sub Main
	Dim part As PartDocument = ThisDoc.Document
	Dim body As SurfaceBody = part.ComponentDefinition.SurfaceBodies(1)
	Dim distance As Double = 0.05
	Dim edges As EdgeCollection = ThisApplication.TransientObjects.CreateEdgeCollection()
	For Each edge As Edge In body.Edges
		edges.Add(Edge)
	Next
	part.ComponentDefinition.Features.ChamferFeatures.AddUsingDistance(edges, distance)
End Sub
Message 3 of 14
kresh.bell
I work with multibody part. Is it possible, when I run rule, that I need select body for chamfer and field for chamfer value?
Message 4 of 14
Michael.Navara
Yes, you can use Pick Method for selecting body and InputBox for input distance value.
Sub Main
	Dim body As SurfaceBody = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select part") ' part.ComponentDefinition.SurfaceBodies(1)
	Dim distance As Double =  Double.Parse(InputBox("Chamfer distance", "iLogic", 0.05)) ' 0.05
		edges.Add(Edge)
	Next
End Sub
Message 5 of 14
kresh.bell
Perfect,
but I think that iLogic have minor bug. If I want chamfer 2, in field must be 0,2
Message 6 of 14
FINET_Laurent
Hi @kresh.bell,
Inventor internaly uses centimeters. If you create a double with a value of 1, it will read 1cm what ever the document unit is. If you want your distance to be 1mm, you'll need to convert it by dividing the input value by 10 :
Dim distance As Double =  (Double.Parse(InputBox("Chamfer distance", "iLogic", 0.05))) /10 ' 0.05
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 7 of 14
Michael.Navara
This is because Inventor's internal units are [cm]. You need to convert input string to appropriate numeric value in required units.
Message 8 of 14
kresh.bell
Thanks, it works perfect
Message 9 of 14
kresh.bell
Is it big problem add option multibody select?
Message 10 of 14
FINET_Laurent
@kresh.bell,
I'm not sure to understand correctly your request ? What would be the workflow?
To be able to select one or more solid bodies by click?
Kind regards,
FINET L.
Message 11 of 14
kresh.bell
yes
Message 12 of 14
FINET_Laurent
Hi @kresh.bell,
Note you can mark multiple replies as solutions for your topic. Here is a code that let you pick multiples surfacebodies. When you are done selecting, simply press "esc" to create the chamfers :
Sub Main
	Dim doc As Inventor.PartDocument = ThisApplication.ActiveDocument
	Dim partdef As Inventor.PartComponentDefinition = doc.ComponentDefinition
	Dim bodyCol As Inventor.ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For i As Integer = 1 To partdef.SurfaceBodies.Count
		If body Is Nothing Then Exit For
		If check(body, bodyCol) = False Then  bodyCol.Add(body)
	Next
	Dim distance As Double = (Double.Parse(InputBox("Chamfer distance", "iLogic", 0.05))) / 10 ' 0.05
	For Each body As Inventor.SurfaceBody In bodyCol
			edges.Add(Edge)
		Next
	Next
	partdef.Features.ChamferFeatures.AddUsingDistance(Edges, distance)
End Sub
Private Function check(input As Object, col As Inventor.ObjectCollection)
	If col.Count = 0 Then Return False
	For Each obj As Object In col
		If obj is input Then Return True
	Next
	Return False
End Function
Does this suits your needs ?
Kind regards,
FINET L.
Message 13 of 14
kresh.bell
Perfect, thanks
Message 14 of 14
kresh.bell
iLogic works perfect. Is it possible, when I select bodies, that selected bodies be highlights
