Centralize Dimension Text
Message 1 of 11
Hello, I am trying to edit the text on a dimension and at the same time center justify the text.  I am able to do this, but when I add the line of code (oDim2.Text.FormattedText = oDim2.Text.VerticalJustification), the dimension appears justified with the text I added, but it has an unwanted series of trailing numbers (seen in the attached image). Any ideas of how to correct this?  Thank you!
Dim oDim2 As GeneralDimension
oDim2=oGeneralDims.AddLinear(oPt2,oSheet.CreateGeometryIntent(oBH),oSheet.CreateGeometryIntent(oTH))
String1 = (Parameter("PLATE MAG.iam.NO_OF_HOLES")/2)-1 & " SPACES @ " & RoundToFraction(Parameter("PLATE MAG.iam.INNER_LENGTH_HOLE_SPACING"),1/16,RoundingMethod.Round) & vbCrLf & " = "
oDim2.text.FormattedText = oDim2.Text.VerticalJustification
oDim2.text.formattedtext = String1 & oDim2.text.FormattedText
oDim2.CenterText
Replies (10)
Message 2 of 11
bradeneuropeArthur
I have written an add in to achieve the same.
If wanted I can share it with you.
Send me a private message how I can reach you.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
bradeneuropeArthur
You will have to set the precision to "0" when reference the parameter I think.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 11
danmachen
This code is available in the native Inventor API/ samples.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-DE98632B-3DC0-422B-A1C6-8A5A15C99E11
Check out the others there. You can remove the 'set' to make most of them work out of the box.
Here is the snippet directly from there (but with a few updates)
doc = ThisDoc.Document
If doc.DocumentType = kDrawingDocumentObject Then
    ' Set a reference to the active drawing document
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet
    Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    Dim oDrawingDim As DrawingDimension
    ' Iterate over all dimensions in the drawing and
    ' center them if they are linear or angular.
    For Each oDrawingDim In oSheet.DrawingDimensions
        If TypeOf oDrawingDim Is LinearGeneralDimension Or _
           TypeOf oDrawingDim Is AngularGeneralDimension Then
            Call oDrawingDim.CenterText
    Next
Else If doc.DocumentType = kAssemblyDocumentObject Then
MessageBox.Show("This is an assembly file.", "iLogic")
Else If doc.DocumentType = kPartDocumentObject Then
MessageBox.Show("This is a part file.", "iLogic")
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
Message 5 of 11
bradeneuropeArthur
The dimensions to center is not his problem.
The visually is the problem.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 11
dgreatice
Hi All,
I think he just wrong code in :
it must be :
oDim2.text.FormattedText = String1
oDim2.Text.VerticalJustification = 'kAlignTextBaseline or kAlignTextLower or kAlignTextMiddle or kAlignTextUpper <-- choose one
and add too :
oDwgDim.Text.HorizontalJustification = 'kAlignTextCenter kAlignTextLeft kAlignTextRight <-- choose one
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 7 of 11
bradeneuropeArthur
He has also added parameters to the dimension format.
this is to be defined different I think.
When I read the formatted text it is different.
So please upload the necessary information.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 11
@dgreaticethis format allowed me to run the code without errors and without additional text being generated into the dimension, but it still did not center justify the text.  I'm not sure if I can center justify the text AND split it into two lines, but it is acceptable as is and I suppose it will have to do.  Thank you
Message 9 of 11
dgreatice
Can you give a example about justify the text with screenshoot? We will compare what do you want about justify a text with first uploading capture from you.
Message 10 of 11
By justified I mean centered within the text box, as seen by comparing the two images attached here.
Message 11 of 11
dgreatice
Now, can i see you new code after i revised you code?
I think at last code with :
oDim2.CenterText
oDim2.Text.HorizontalJustification = kAlignTextCenter
Is enough.
