Center dims code
Center dims code
blandb
Mentor Mentor
Center dims code
blandb
I took this from the api help, and modified it based on a video I found, but any ideas as why this needs to be ran twice to get all dims??
    ' Set a reference to the active drawing document
    Dim oDoc As DrawingDocument
    oDoc = ThisDoc.Document
    ' Set a reference to the active sheet
    Dim oSheet As Sheet
     oSheet = oDoc.ActiveSheet
    Dim oDrawingDim As DrawingDimension
    ' Iterate over all dimensions in the drawing and
    ' center them if they are linear or angular.
    For Each oDrawingDim In oSheet.DrawingDimensions
        If TypeOf oDrawingDim Is LinearGeneralDimension Or _
           TypeOf oDrawingDim Is AngularGeneralDimension Then
            oDrawingDim.CenterText
    Next
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
Autodesk Certified Professional
alewer
I am dealing with the exact same problem and would love if anyone has a solution. In my case it is a c# addin.
bradeneuropeArthur
It not a real big problem.
I have solved it this way
End If Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
alewer
We have pretty much done the same. However it is a bit annoying and I was hoping somebody had a "proper" fix. Calling CenterText() twice is not an extreme burden, but it is still a workaround. I am guessing this is a bug and we will be using this workaround for a long time to come.
