Caps Lock
Caps Lock
AMN3161
Caps Lock
AMN3161
Hello
This is probably a simple question but I am doing a look up at a excel document and replacing the iproperty "description" I saw that you add ".ToUpper)" to the code to make it caps but I am not 100% sure how to implement it
thank you ahead of time
bradeneuropeArthur
Every string has a ToUpper or ToLower function.
Dim Qwerty  as string
Qwerty thIS
Qwerty.ToUpper gives THIS
Qwerty.ToLower gives this
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Try the code below.
To test: Create a part file "Part-001.ipt", then run the code. Then save as the file to "Part-002.ipt", run the code again and check iproperties.
'Get the filename
Dim oFileName As String = ThisDoc.FileName(False) 'without extension
'Check if it is correct
MessageBox.Show(oFileName, "File Name")
'This will automatically find your filename in the excel
oExcelFile = GoExcel.FindRow("C:\Test\Test.xlsx", "Sheet1", "Part Name", "=", oFileName)
'This will find your "Description" column in the excel. Should be typed exactly.
ExcelDesc = GoExcel.CurrentRowValue("Description")
'Check if it is reading from excel
MessageBox.Show(ExcelDesc, "Description from excel")
'ToUpper or ToLower
MessageBox.Show(ExcelDesc.ToUpper, "ToUpper / ToLower")
iProperties.Value("Project", "Description") = ExcelDesc.ToUpper
AMN3161
Could you attached the IPT file? i think you forgot to
WCrihfield
Here's the simplest example using only iLogic:
Copy this code into a new rule, then run it.
Dim oStr As String = "cAse"
MsgBox("oStr = cAse" & vbCrLf & _
"oStr.ToUpper = " & oStr.ToUpper & vbCrLf & _
"oStr.ToLower = " & oStr.ToLower,vbOKOnly+vbInformation," ")
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS 💡and Explore My CONTRIBUTIONS
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
