Cannot get PartsList
1354448288
1354448288
Here is my code:
PartsList partsList = drawingDocument.ActiveSheet.PartsLists[1];
When I continue:
MessageBox.Show(partsList.PartsListRows[0].ReferencedFiles[0].ToString());
I cannot get anything, and will get a message(an exception)
$exception HRESULT:0x80070057 (E_INVALIDARG))System.ArgumentException
Michael.Navara
First item in collections in Inventor has index 1
MessageBox.Show(partsList.PartsListRows[1].ReferencedFiles[1].ToString());
I explained the exception a wrong way. The real problem is that :
int num = partsList.MaximumRows;
Then, I get a message: exception from HRESULT:0x80004005 (E_FAIL))
I indeed get the partlist, and can print partslist.title partslist.layer, but I cannot get partsList.MaximumRows
Michael.Navara
OK this member returns exception but you can use another approach
var partsList = drawing.ActiveSheet.PartsLists[1];
int rowsCount = partsList.PartsListRows.Count;
foreach (PartsListRow row in partsList.PartsListRows)
    string displayName = row.ReferencedFiles[1].DisplayName;
    //Logger.Debug(displayName);
Thank you !! I just found the same way.
But I am still curious about why cannot get partsList.MaximumRows.
JelteDeJong
 I expect that partsList.MaximumRows is a reference to the maximum number of rows before a new column  is added to your part list.
Jelte de Jong
Blog: hjalte.nl - github.com
