Cannot create ActiveX component error when writing to excel
Inventor 2018, Excel 2016, Windows 7 enterprise
Here is the code I have been using
Here is the error message
This code does work on other machines.
bradeneuropeArthur
Can you please upload your complete code, so we can test it?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Please go through below system requirements for Inventor 2018.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Inventor-2018.html
Basically, Inventor 2018 is 64 bit application. Just guessing that excel 2016 would be 32 bit application. This might be root cause for error.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
I cannot upload the rest of the rules but they all work. It is just the excel rule that is broken.
bradeneuropeArthur
If I remove the first line ....Open(....) then it works.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Unfortunately I am still getting the error without the first line.
