Can you query the current vault user?
mslosar
Advisor Advisor
Message 1 of 16
mslosar
Is there any method for doing this inside Inventor? I switch back and forth from basic user to admin and there are times you forget which one was which, etc.
I'd just like a way to determine which user i'm presently logged in with WITHOUT having to log out and back in.
Replies (15)
Message 2 of 16
bradeneuropeArthur
What version of vault are you using.
And yes that is possible
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 16
mslosar
We're on 2017 on both inventor and vault.
Should be moving to '19 this summer.
Message 4 of 16
bradeneuropeArthur
vault pro?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 16
bradeneuropeArthur
See this simular solution.
https://forums.autodesk.com/t5/inventor-customization/use-inventor-vault-add-in-through-inventor-api...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 16
mslosar
Looks like it should work rather simply with the vb excerpt at the bottom. I'll give it a whirl and let you know, thanks 🙂
Message 7 of 16
bradeneuropeArthur
I can provide you the code next week. About the user that is logged in.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 16
mslosar
I think i'm missing a reference...not sure. It won't let me use
Imports Connectivity.InventorAddin.EdmAddin
Says Connectivity is not declared.
I've added that and Autodesk.DataManagement.Client.Framework.Vault.dll to the reference manager.
Is it an issue i had to browse to them instead of them popping up in the list?
Message 9 of 16
mslosar
All right.
I think something is misconfigured. I found a post on it that showed someones list of references. I've got all those added and same error with Connectivity is not declared.
If i try and type in the Imports line, i don't get sub choices of Autodesk or Connectivity, my list is:
<namespace alias>
<xmlns>
Inventor
Microsoft
Stdole
System
My Project
Message 10 of 16
bradeneuropeArthur
C:\Program Files\Autodesk\Inventor 20xx\Bin\Autodesk.DataManagement.Client.Framework.Vault.dll
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 16
bradeneuropeArthur
I have this working for an inventor add in.
So I don't use stand alone apps.
Create a new inventor add in and paste the code in there. Or provide the add in code and I will add the needed code.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 16
mslosar
This is an add-in as well.
I figured out the problem of why the connectivity wasn't working. .Net Framework.
I've been adding to this add-in suite of mine for years. It was written originally under .Net 3.5. The trick in getting it to work was to up it to 4.5. That fixed those errors and got it working. And all i needed was rather simple in the end:
Public Sub WhoIsMe(ThisApplication As Inventor.Application)
        Dim strVaultUserName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.UserName
        MsgBox(strVaultUserName, MsgBoxStyle.Information, "Vault User Logged In")
    End Sub
That will simplify my life a lot 🙂
However the update to .Net 4.5 gives me warnings now.  Not exactly sure how to fix them. Any ideas?
Message 13 of 16
bradeneuropeArthur
You are using a older interop?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 16
mslosar
I went into the references and turned the flag to false on the interop and those 3 went away.
Now if i could figure out what was referencing the same dependent stuff, that would help. If it knows there's a conflict, you'd think it could tell you what's doing the conflicting.
Message 15 of 16
mslosar
Why does this work under vb but not c#?
When i try and use it it says: EdmSecurity.GetEdmLoginPreferences() is a method, which is not valid in the available context.
All the same references are set as well as the using statement.
Message 16 of 16
mslosar
Looks like the 2019 version changed.
This works:
EdmSecurity test = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance;
MessageBox.Show(test.VaultConnection.UserName);
