Can we create a KnitFeature using a singular, closed surfacebody?
gerrardhickson
gerrardhickson
Is there any way to create a KnitFeature from a single (closed) surface body to turn it into a solid?
From the UI, its easy enough - but through VBA it errors out.
To reproduce:
  • Create a solid extrusion
  • Use "copy object" to create a surface copy of it.
  • Delete or Hide the source solid body
  • Then via VBA - add the single surface body to an object collection
  • Create a Knit Feature using the object collection.
    Dim oSurfs As ObjectCollection
    Set oSurfs = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oWS As WorkSurface
    For Each oWS In oPartDef2.WorkSurfaces
        If oWS.SurfaceBodies(1).AffectedByFeatures(1).Name = oBaseFeature1.Name Then
            oSurfs.Add oWS
        End If
    Next oWS
    Dim oStitch As KnitFeature
    Set oStitch = oPartDef2.Features.KnitFeatures.Add(oSurfs, 0.005, False)
Appreciate the help.
gerrardhickson
I now realise this is a duplicate post. Please disregard.
Refer here: https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-gt-stitch-composite-surface-body...
