Can't run regasm
Can't run regasm
Can't run regasm
I have been trying to understand AddIns and ran the SimpleAddIn Sample, I am trying to unregister the AddIn but regasm is not recognised?
Any ideas?
Regards Malcolm
You will need to specify the path where regasm exists. For example, if you
have .NET framework 2.0, regasm.exe is here:
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
Either update the path environment variable to include the folder above or
just change the current directory to the folder above. Then type regasm /u
"full file name of addin dll" so that regasm can find the dll.
-Venkatesh.
Thanks Venkatesh that worked fine.
I include the full command path if anyone else needs it.
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm /u "C:\Program Files\Autodesk\Inventor 2009\SDK\DeveloperTools\Samples\VB.NET\AddIns\SimpleAddIn\bin\SimpleAddIn.dll"
