Standard Inventor Command
I want to execute a standard Inventor command with my
C# makro.
The command is to insert a symbol in the current idw file.
Which CommandIDEnum i have to use in my Code ?
InventorApp.CommandManager.StartCommand(
CommandIDEnum. ?)
Greetings
A. Engler
Hi Andreas,
why do you want to use a inventor command.
When you want to insert a sketched symbol, you can use the APi.
There is an example in the Help.
Look for SketchedSymbolDefinition Object.
Best regards
JesG
Hello JesG,
I want to use the original Inventor Dialog
to insert a symbol.
Greetings
A. Engler
If you want to execute the "Symbols" command on the "Drawing Annotation
Panel" (which brings up a dialog), then
ThisApplication.CommandManager.ControlDefinitions("DrawingSymbolsCmd").Execute
If you want to start the command to insert a sketch symbol:
ThisApplication.CommandManager.ControlDefinitions("DrawingUserDefinedSymbolsQuickCtxCmd").Execute
But, for the latter, you need to specify the sketch symbol to insert (maybe
by pre-selecting it).
-Venkatesh.
Thank you Venkatesh
Greetings
A. Engler
