Can someone tell me whats wrong with this simple add-in??
HI!
when i hit the created add-in button, the inventor display a error, and i'm not understanding why.
can someone check this for me?
THANKS.
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Namespace Num_desenhos
GuidAttribute("aca8e62a-a403-47b9-ab48-e313ebf86673")> _
Public Class StandardAddInServer
Implements Inventor.ApplicationAddInServer
' Inventor application object.
Private m_inventorApplication As Inventor.Application
Private WithEvents m_ButtonDef As ButtonDefinition
Private m_ClientID As String
#Region "ApplicationAddInServer Members"
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
' This method is called by Inventor when it loads the AddIn.
' The AddInSiteObject provides access to the Inventor Application object.
' The FirstTime flag indicates if the AddIn is loaded for the first time.
' Initialize AddIn members.
m_inventorApplication = addInSiteObject.Application
' TODO: Add ApplicationAddInServer.Activate implementation.
' e.g. event initialization, command creation etc.
m_ClientID = AddInGuid(GetType(StandardAddInServer))
Dim oUIManager As UserInterfaceManager = m_inventorApplication.UserInterfaceManager
Dim controldefs As ControlDefinitions
controldefs = m_inventorApplication.CommandManager.ControlDefinitions
m_ButtonDef = controldefs.AddButtonDefinition("Numera desenhos", "AddIn_numera_desenhos", CommandTypesEnum.kQueryOnlyCmdType, m_ClientID, "Adiciona app para numerar desenhos", "Numera desenhos")
If firstTime = True Then
If oUIManager.InterfaceStyle = InterfaceStyleEnum.kClassicInterface Then
Dim commandbars As CommandBars
commandbars = m_inventorApplication.UserInterfaceManager.CommandBars
Dim commandbar As CommandBar
commandbar = commandbars.Add("addins_nm", "AuAddin_nm", CommandBarTypeEnum.kRegularCommandBar, m_ClientID)
commandbar.Visible = True
commandbar.Controls.AddButton(m_ButtonDef)
End If
End If
End Sub
Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
' This method is called by Inventor when the AddIn is unloaded.
' The AddIn will be unloaded either manually by the user or
' when the Inventor session is terminated.
' TODO: Add ApplicationAddInServer.Deactivate implementation
' Release objects.
Marshal.ReleaseComObject(m_inventorApplication)
m_inventorApplication = Nothing
System.GC.WaitForPendingFinalizers()
System.GC.Collect()
End Sub
Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation
' This property is provided to allow the AddIn to expose an API
' of its own to other programs. Typically, this would be done by
' implementing the AddIn's API interface in a class and returning
' that class object through this property.
Get
Return Nothing
End Get
End Property
Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand
' Note:this method is now obsolete, you should use the
' ControlDefinition functionality for implementing commands.
End Sub
#End Region
#Region "COM Registration"
' Registers this class as an AddIn for Inventor.
' This function is called when the assembly is registered for COM.
_
Public Shared Sub Register(ByVal t As Type)
Dim clssRoot As RegistryKey = Registry.ClassesRoot
Dim clsid As RegistryKey = Nothing
Dim subKey As RegistryKey = Nothing
Try
clsid = clssRoot.CreateSubKey("CLSID\" + AddInGuid(t))
clsid.SetValue(Nothing, "Num_desenhos")
subKey = clsid.CreateSubKey("Implemented Categories\{39AD2B5C-7A29-11D6-8E0A-0010B541CAA8}")
subKey.Close()
subKey = clsid.CreateSubKey("Settings")
subKey.SetValue("AddInType", "Standard")
subKey.SetValue("LoadOnStartUp", "1")
'subKey.SetValue("SupportedSoftwareVersionLessThan", "")
subKey.SetValue("SupportedSoftwareVersionGreaterThan", "12..")
'subKey.SetValue("SupportedSoftwareVersionEqualTo", "")
'subKey.SetValue("SupportedSoftwareVersionNotEqualTo", "")
'subKey.SetValue("Hidden", "0")
'subKey.SetValue("UserUnloadable", "1")
subKey.SetValue("Version", 2)
subKey.Close()
subKey = clsid.CreateSubKey("Description")
subKey.SetValue(Nothing, "Num_desenhos")
Catch ex As Exception
System.Diagnostics.Trace.Assert(False)
Finally
If Not subKey Is Nothing Then subKey.Close()
If Not clsid Is Nothing Then clsid.Close()
If Not clssRoot Is Nothing Then clssRoot.Close()
End Try
End Sub
' Unregisters this class as an AddIn for Inventor.
' This function is called when the assembly is unregistered.
_
Public Shared Sub Unregister(ByVal t As Type)
Try
clssRoot = Microsoft.Win32.Registry.ClassesRoot
clsid = clssRoot.OpenSubKey("CLSID\" + AddInGuid(t), True)
clsid.SetValue(Nothing, "")
clsid.DeleteSubKeyTree("Implemented Categories\{39AD2B5C-7A29-11D6-8E0A-0010B541CAA8}")
clsid.DeleteSubKeyTree("Settings")
clsid.DeleteSubKeyTree("Description")
Catch
Finally
End Try
End Sub
' This property uses reflection to get the value for the GuidAttribute attached to the class.
Public Shared ReadOnly Property AddInGuid(ByVal t As Type) As String
Get
Dim guid As String = ""
Try
Dim customAttributes() As Object = t.GetCustomAttributes(GetType(GuidAttribute), False)
Dim guidAttribute As GuidAttribute = CType(customAttributes(0), GuidAttribute)
guid = "{" + guidAttribute.Value.ToString() + "}"
Finally
AddInGuid = guid
End Try
End Get
End Property
#End Region
Private Sub m_ButtonDef_OnExecute(ByVal Context As Inventor.NameValueMap) Handles m_ButtonDef.OnExecute
Dim form As Form1
form = New Form1
form.InventorDocument = m_inventorApplication.ActiveDocument
form.Show()
End Sub
End Class
End Namespace
Hi!
I really need help, i dont know what is going on.
Inventor returns the following error:
is not possible to associate the COM object of type 'Inventor._DocumentClass' type of interface'Inventor. AssemblyDocument'.
This operation failed because the QueryInterface call on the COM component for the interface with IID '(xxxxxx)' failed with the following error:
No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Can you post the StandardAddInServer.vb file. I tried to paste your code in
to a new one, but it comes in all as one line.
KWiKMcad
Kent Keller
"SMachado" wrote in message news:6384920@discussion.autodesk.com...
Hi!
(E_NOINTERFACE)).
Hi Kent!
I have solved the problem, it was a problem on the form load event
thanks.
