Automatically generate a drawing
Message 1 of 11
Would it be possible to use a macro to automatically generate a drawing of a sheet metal flat pattern?
Replies (10)
Message 2 of 11
Rene-J
Hi
Try this code
Public Sub SMToIDW()
Dim oPartDoc As Document
Set oPartDoc = oApp.ActiveDocument
If oPartDoc.DocumentType <> kPartDocumentObject Then
MsgBox "The Active document must be a 'Part'"
Exit Sub
' The Active document must be a Skeet metal Part
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Exit Sub
'call drawing template'
Dim oDrawingDoc As DrawingDocument
Set oDrawingDoc = oApp.Documents.Add(kDrawingDocumentObject, oApp.FileOptions.TemplatesPath & "Standard.idw", True)
'Delete Titleblock and Border
Dim oSheet As Sheet
Set oSheet = oDrawingDoc.ActiveSheet
oSheet.Size = kA3DrawingSheetSize
oSheet.Border.Delete
oSheet.TitleBlock.Delete
'set View scale to 1:1
Dim VScale As Double
VScale = 1
Dim oDrawingViews As DrawingViews
Dim oDV As DrawingView
Set oDrawingViews = oDrawingDoc.Sheets(1).DrawingViews
Dim oOptions As NameValueMap
Set v_org = oApp.TransientGeometry.CreatePoint2d(0, 0)
Set oOptions = oApp.TransientObjects.CreateNameValueMap
Call oOptions.Add("SheetMetalFoldedModel", False)
'Create flatpattern view
Set oDV = oDrawingViews.AddBaseView(oPartDoc, v_org, VScale, kDefaultViewOrientation, _
kHiddenLineRemovedDrawingViewStyle, , , oOptions)
'Adjust View skala to drawing
oDV.[Scale] = Viewscale(oDV.Width, oDV.Height)
'move View to 0,0
Set l_org = oApp.TransientGeometry.CreatePoint2d((oDV.Width / 2), (oDV.Height / 2))
oDV.Center = l_org
End Sub
Private Function Viewscale(ByVal viewL As Double, ByVal viewH As Double) As Double
If (viewL < viewH) Then
viewL = viewH
viewL = (viewL * 10) 'from cm to mm
If viewL > 250 Then
Viewscale = (1 / (viewL / 250))
Else
Viewscale = 1
End Function
Message 3 of 11
Thanks for the guidance, I'll give it a go!
Message 4 of 11
A couple of modifications -
Set oPartDoc = ThisApplication.ActiveDocument
all "oDoc" changed to "ThisApplication"
and it does what it says on the tin!!
Thank you very much.
Message 5 of 11
Hi Peter, Ive been 3d modelling for 10+ years however my macro/vb/c++ skills are zero.
I contracted for a company 3 years ago who used solid works (yuk) however a programmer there had created a macro that produced from an assembly file:
1. Individual pages of every part with in the assy
2. Plan orthographic views and a section view... on each page to a scale that suited the page, (as scale rules etc arent as widley used these days, a random scale is sufficient.
Im pretty sure the programing language is similar between Inventor and Solid works, if I sent you that code do you think you could adapt it to be used for Inventor?
Look forward to a response.
Could you please also point me in the right direction for a macro that can: open part from directory, create flat pattern, save, close file, open next file in directory...repeat . I would be very geatfull.
heres a link to the post.
http://forums.autodesk.com/t5/Autodesk-Inventor/Automate-part-placement-on-an-idw-from-an-iam/m-p/27...
Regards, Stefan.
Message 6 of 11
Hi there I was wondering if you can help me with the following:
Can you point me in the right direction for a macro that can: open part from directory, create flat pattern, save, close file, open next file in directory...repeat 290 times. I would be very greatfull.
regards Stefan.
Message 7 of 11
Rene-J
Hi Stefan
Try this Addin  iFlatpatternExport
http://www.mcadforums.com/forums/viewtopic.php?f=34&t=11249
In The addin
Set  Auto export on save sheetmetal part
set  on save create flattpattern if not exist
Use the Inventor task scheulder
create a task update design, select  directory,  select *.ipt in filename
and run the task.
René J
1126i60495B4243F18CBB
Message 8 of 11
I wrote a sucessful add-in that included the generation of a flat pattern if one didn't exist.  But that was back a while, maybe R9 or R10.
Currently I don't recommend trying to automatically create a flat pattern due to the rather illogical way IV now creates a flat pattern if you don't select the base face (something seems to have changed).  It may be my code, but if I automatically create a flat pattern it is invariably the wrong hand!
See
http://forums.autodesk.com/t5/Autodesk-Inventor/Illogical-sheet-metal-flat-pattern/m-p/2558612
Rene, I'll give your add-in a try.
Message 9 of 11
Thanks very much, i'll give that a crack.
Stefan
Message 10 of 11
Thanks Peter,Out of habbit I always choose the base face generally, (according to good face, folds down for sheetmetal drawings)
Luckily this job has no folds, and inventors random approach on this one occasion will be ok.
p.s I used to develop some tricky sheetmetal parts,and as you would know, the flat pattern some times wont generate at all untill you manually go through every possible face. I remember the days of mechanical desktop along with the add in Autopol, that would unfold almost anything, it would even unfold a deep drawn flange or pocket that had no corner seams.
Thanks again,
Stefan
Message 11 of 11
I know this post is really old but would you be willing to help edit your macro a little.  I have almost no coding experience and can't get it to do what I want.
