Can I check out the third party of the inventor dwg from the vault using ilogic?
skseo
skseo
Can I check out the 3rd party of the inventor dwg from the vault using ilogic?
3rd party document : autocad dwg, pdf
vault version : 2022 Professional
bradeneuropeArthur
Could you tell me if the files are only Vault attachments or that they are Inventor Third-party files as linked items?
Could you otherwise share an file with this structure?
Arthur Knoors
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
skseo
Thank you for your interest in my question.
Attach a file related to the question.
