Call an iLogic Global Form from within a Macro
fsdolphin
fsdolphin
Hi, I have a global form that I constantly use so, I would like to be able to call the Form using a shortcut.  I was thinking to create a Macro, call the Form from the Macro and then create a shortcut for the Macro.  Similar to the way you would call an iLogic rule from a Macro.
Is there a way to call an iLogic Global Form from within a Macro in Inventor?
Or better yet, is it possible to create a shortcut to a Global Form without creating a Macro?
Ref: Call iLogic Rules From a Macro
Inventor: Run iLogic Rules from your Ribbon – Cadline Community
Thanks a lot!
JhoelForshav
Hi @fsdolphin
Here's a quick way I could think of to show a global form through a VBA macro. It'll temporarily create an iLogic-rule that will display the form and then be deleted.
Sub ShowGlobalForm()
Set iLogicVb = ThisApplication.ApplicationAddIns.ItemById("{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}")
Set iLogicAuto = iLogicVb.Automation
'Create iLogic rule that shows the form (executes automatically)
Call iLogicAuto.AddRule(ThisApplication.ActiveDocument, "showForm", "iLogicForm.ShowGlobal(""Form 1"")") 'Change "Form 1" to name of your form
'Delete the rule
Call iLogicAuto.DeleteRule(ThisApplication.ActiveDocument, "showForm")
End Sub
fsdolphin
It worked, thanks a lot for your help.
