Ilogic to copy .dwg balloon override value to assembly/part instance value IV2022
cameron.florenceJMGNL
Hi
I need to make a rule that copies the balloon override values of assembly parts in a .dwg to the new part instance property, available in IV2022.  I have been learning to write basic ilogic for a while now but am not at the level where I can sort this one out. 🤔
Any help would be amazing.
Cheers
JhoelForshav
Hi @cameron.florenceJMGNL
Try running this code in your drawing document to set the instance property "Balloon value" for all occurrences with balloons attached to them 🙂
Dim oDoc As DrawingDocument = ThisDrawing.Document
For Each oSheet As Sheet In oDoc.Sheets
	For Each oBalloon As Balloon In oSheet.Balloons
		Dim oVal As String
		If oBalloon.BalloonValueSets(1).Static 'Check if value is overridden
			oVal = oBalloon.BalloonValueSets(1).OverrideValue
		Else
			oVal = oBalloon.BalloonValueSets(1).Value
		'Get the occurrence the balloon is attached to
		Dim Leader As Leader = oBalloon.Leader
		Dim oLeaderNode As LeaderNode = Leader.AllNodes(2)
		Dim oIntent As GeometryIntent = oLeaderNode.AttachedEntity
		Dim oCurve As DrawingCurve = oIntent.Geometry
		Dim oProx As EdgeProxy = oCurve.ModelGeometry
		Dim oOcc As ComponentOccurrence = oProx.ContainingOccurrence
		'Set the instance property "Balloon value"
		oOcc.OccurrencePropertySetsEnabled = True
		Try
			oOcc.OccurrencePropertySets.Item(1).Add(oVal, "Balloon value")
		Catch
			oOcc.OccurrencePropertySets.Item(1).Item("Balloon value").Value = oVal
		End Try
	Next
Next
 that number/tag to the instance iProperty of the part.
If anyone has the capability to write some code to do this, it would be so helpful.
