C# iLogic Automation
Daan_M
Daan_M
Hi forum,
The code below adds iLogic and then runs a rule of my choice. which is great.
Now i want to run a rule multiple times, i call 'AddiLogic()' elsewhere in my code when i need the rule to run.
I assume it's not needed to run this whole block of code just for the rule to run. I think i only need the last part of block, so i could split the block into two:
one does AddiLogic();
the other does RunRule();
the problem is that i'm quite new to coding and when i split it it looses all references and creates a whole list of errors, see the code further below for what my goal is...
void AddiLogic()
            string MyRuleName = textBox2.Text;
            string iLogicAddinGuid = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}";
            ApplicationAddIn iLogicAddin;
            dynamic iLogicAutomation = null;
            try
                iLogicAddin = _invApp.ApplicationAddIns.ItemById[iLogicAddinGuid];
                iLogicAutomation = iLogicAddin.Automation;
            catch (Exception ex)
                MessageBox.Show("Unable to access iLogic addin " + ex.Message);
            // niet nodig om de hele AddIlogic toe te voegen, alleen de rule uitvoeren is voldoende...
            try
                iLogicAutomation.Runrule(oDoc, MyRuleName);
            catch
                MessageBox.Show("There is no rule called " + MyRuleName);
   void AddiLogic()
            try
        void RunRule()
                try
                catch
chandra.shekar.g
Autodesk Support
Autodesk Support
@Daan_M,
Try suggestion in the below blog link.
https://adndevblog.typepad.com/manufacturing/2013/09/run-ilogic-rule-from-external-application.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
