Save iProperty info to Excel from dwg files
MH-J
MH-J
Hello all.
I've created an array list of all dwg files in a directory structure and wish to iterate through each of them and send the part number, description, revision and creation date iProperties through to the excel sheet. Everything is fine except for the reading and writing of the iProperties. The code I have is as noted below and fails stating the following
iProperties:The document named "C:\Users\Public\Documents\Dropbox\design work\SAB\01-Design\00-Product Codes\01-RB1.8\02-Design\01-RB1.8.dwg" was not found.
Thanks for any help
Dim oDrawingNumbers() As String = System.IO.Directory.GetFiles(oPath, "*.dwg", System.IO.SearchOption.AllDirectories)
For Each Drawing As String In oDrawingNumbers
	If (InStr(1, Drawing, "OldVersion")) Then  'Do nothing with this file as it is in the OldVersions Folder
	Else	'This is a live drawing
		GoExcel.CellValue("A" & oRow) = iProperties.Value(Drawing, "Project", "Description")
		GoExcel.CellValue("B" & oRow) = iProperties.Value(Drawing,"Project", "Description")
		GoExcel.CellValue("C" & oRow) = iProperties.Value(Drawing, "Project", "Revision")
		GoExcel.CellValue("D" & oRow) = iProperties.Value(Drawing,"Project", "Creation Date")
		oRow = oRow+1
Next
Curtis_W
Hi @MH-J
Try something along these lines.
I hope this helps.
Curtis
oPath = "C:\Temp"
oExt = "*.idw"
Dim oDrawingNumbers() As String = System.IO.Directory.GetFiles(oPath, oExt, System.IO.SearchOption.AllDirectories)
		Dim oOptions As Inventor.NameValueMap
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		Dim oDoc As DrawingDocument
	If Drawing.Contains("OldVersion") = False Then
		'false opens invisibly
		oDoc = ThisApplication.Documents.OpenWithOptions(Drawing, oOptions, False)
		oPN = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
		MsgBox(oPN)
Next
mikejones
Thanks for the quick response Curtis.
I've added the lines of code in which appears to work but I was hoping for a solution that would interrogate the files iProperties without having to open it up. Would that be feasible?
Mike
Autodesk Certified Professional
Curtis_W
Hi @mikejones ,
Unfortunately,  I don't know of a way to access the iproperties via iLogic/VB without having the file already opened or without opening  the files if they are not already opened.
I hope this helps.
Curtis
