BrowserNode.Expanded = True throws an exception
Anton_Chernomazov
Anton_Chernomazov
I'm using C# Inventor AddIn to search an BrowserNode object in BrowserPane and execute some command. When I have target BrowserNode I try to set Expanded propery value as True. But in this case an exception occurs. How to expand BrowserNode?
JelteDeJong
I did a small test. This is my test code and it works like expected.
PartDocument doc = (PartDocument)ThisDoc.Document;
BrowserNode node = doc.BrowserPanes["Model"].TopNode;
BrowserNode childNode = node.BrowserNodes[1];
childNode.Expanded = true;
 Can you share a bit more of your code and/or the node that you are trying to expand?
Jelte de Jong
Blog: hjalte.nl - github.com
Anton_Chernomazov
This case work for me too. But if I take browser node for drawing view on drawing document and try to expand it I have an exception.
JelteDeJong
I changed my test setup to this code and it still works.
DrawingDocument doc = (DrawingDocument)ThisDoc.Document;
BrowserNode sheetNode = node.BrowserNodes[2];
BrowserNode baseDrawingViewNode = sheetNode.BrowserNodes[3];
baseDrawingViewNode.Expanded = true;
BrowserNode projectedDrawingViewNode = sheetNode.BrowserNodes[3];
projectedDrawingViewNode.Expanded = true;
Jelte de Jong
Anton_Chernomazov
Thank you for reply. I think your case works because you use indexator BrowserNode[object index] to get target node. But I use BrowserPane.GetBrowserNodeFromObject method for DrawingView
