Model data tab export - BOM structure
uo9K5H5
uo9K5H5
I have used the frame insert function and now I have a problem with exporting the BOM structure.
When you use the Frame insert function, a problem arises because the parts only and structured tab adds up the total length of each inserted frame(Shown on the picture). But I would need the information for every imported frame separately. That is why I would like to export data in Model data tab. Is it possible to do so?
WCrihfield
Maybe you can use the 'Part Number Row Merge Settings' tool for this.  You may be able to either un-enable it, or use the 'Merge Exclude List', so it won't 'merge' all those lines together.  Just a thought.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
