Break the link between the "placed" part and the one in the library
I am setting up a library for my company with different types of panels. These panels will be placed from Vault by the end user to their models and need to be modified, e.g. for cut-outs, etc. Is there a way to break the link between the "placed" part and the one in the library, except saving the part as a different one and replacing the former with the latter?
Any idea is appreciated.
Win 7 64-bit
Inventor Pro 2015
Vault Basic 2015
MechMachineMan
a) Look into Custom content center content instead of Standard content center content. (ie; place as custom).
b) Look into "Save & Replace Component" command functionality.
Both methods offer a way to do what you ask depending on whether you are using parts or assemblies.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
