Bounding box with the UCS Origin
ngocson8335
Message 1 of 17
ngocson8335
Dear Expert,
My name is Son, I am a user in the Autodesk Inventor. I have an issue when I get the bounding box with the UCS origin. Please see the attached file for the
Please help me in this case.
Have a nice day.
Ngoc Son
Ngoc Son
Autodesk User
Replies (16)
Message 2 of 17
bradeneuropeArthur
This is not directly the solution but it will help to implement this is future maybe!
You could vote this...….
Dimension Component!
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 17
JamieVJohnson2
If we can't find it, we create it.
Here is some code that will create a range box using the vertices from the solid object, translated to user UCS, calculated for range box, then translated back to origin ucs.
            Dim partDoc As PartDocument = invApp.ActiveDocument
'get 3d solid Dim sb As SurfaceBody = partDoc.SelectSet(1) 'get custom user coordinate system
Dim ucs As UserCoordinateSystem = partDoc.ComponentDefinition.UserCoordinateSystems(1) 'create a list of points (for sorting)
Dim vPoints As New List(Of Point) 'get the transformation matrix from the usc (what it takes to translate from user ucs to origin)
Dim mat As Matrix = ucs.Transformation
'invert the matrix (what it takes to translate from origin to user ucs) mat.Invert()
'cycle through all the points For Each vert As Vertex In sb.Vertices
'get the point data from the vertex Dim p As Point = vert.Point
'invert translate the point data (from origin to user ucs) p.TransformBy(mat)
'add translated point to collection vPoints.Add(p) Next
'create empty min and max points Dim minPoint As Point = tg.CreatePoint(0, 0, 0) Dim maxPoint As Point = tg.CreatePoint(0, 0, 0)
'sort points based on x values, and get lowest and highest value vPoints.Sort(Function(x, y) x.X.CompareTo(y.X)) minPoint.X = vPoints.First.X maxPoint.X = vPoints.Last.X
'sort points based on y values, and get lowest and highest values vPoints.Sort(Function(x, y) x.Y.CompareTo(y.Y)) minPoint.Y = vPoints.First.Y maxPoint.Y = vPoints.Last.Y
'sort points based on z values, and get lowest and highest values vPoints.Sort(Function(x, y) x.Z.CompareTo(y.Z)) minPoint.Z = vPoints.First.Z maxPoint.Z = vPoints.Last.Z
'transform min and max points from user ucs back to origin minPoint.TransformBy(ucs.Transformation) maxPoint.TransformBy(ucs.Transformation)
Note, when I attempted to create a new rangebox (box) object, and assign these min and max points, it behaved oddly, by setting the min and max Z value both to '-0.5'.  This is not the expected behavior as the min/max points have '0.5' and '-0.5'.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 4 of 17
ngocson8335
Hi JamieVJohnson2,
This is for iLogic, I can not run it.
Please
Ngoc Son
Autodesk User
Message 5 of 17
bradeneuropeArthur
what do you need:
VBA
Vb.net
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 17
ngocson8335
iLogic please
Ngoc Son
Autodesk User
Message 7 of 17
bradeneuropeArthur
 Dim partDoc As Inventor.PartDocument
 partDoc = ThisApplication.ActiveDocument
'get 3d solid
			sb = partDoc.SelectSet(1)
			MsgBox (sb.ComponentDefinition.SurfaceBodies.Count)
			MsgBox (partDoc.ComponentDefinition.UserCoordinateSystems.Count)
			ucs = partDoc.ComponentDefinition.UserCoordinateSystems(1)
            Dim mat As Matrix
			mat = ucs.Transformation
            mat.Invert()
                Dim p As Point
				p = vert.Point
                p.TransformBy(mat)
                vPoints.Add(p)
            Next
			 ' Get the corners of the range box.
    		Dim tg As TransientGeometry
    		tg = ThisApplication.TransientGeometry
			minPoint =  tg.CreatePoint(0, 0, 0)
			maxPoint = tg.CreatePoint(0, 0, 0)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 17
ngocson8335
I can not run, some errors. Please, help me to fix.
Ngoc Son
Autodesk User
Message 9 of 17
bradeneuropeArthur
have you added an UCS?
have you selected the part SurfaceBody?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 17
ngocson8335
It still has this problem
Ngoc Son
Autodesk User
Message 11 of 17
ngocson8335
I am using Inventor 2017
Ngoc Son
Autodesk User
Message 12 of 17
JamieVJohnson2
'get 3d solid
            Dim mat As Matrix
            mat.Invert()
                Dim p As Point
				p = vert.Point
                p.TransformBy(mat)
                vPoints.Add(p)
            Next
            minPoint.X = vPoints(0).X
            maxPoint.X = vPoints(vPoints.count-1).X
            minPoint.Y = vPoints(0).Y
            maxPoint.Y = vPoints(vPoint.count-1).Y
            minPoint.Z = vPoints(0).Z
            maxPoint.Z = vPoints(vPoint.count-1).Z
The API is not performing as expected (even the iLogic API can run VB.Net code directly, we are using 2019).  So I modified the .First and .Last statements to their equivalent (0) index value and (vPoints.count-1) index value.
Message 13 of 17
ngocson8335
The next problem. So I'll try to fix it. Thank you for your help.
Ngoc Son
Autodesk User
Message 14 of 17
ngocson8335
Hi JamieVJohnson2,
I can not fix this error. Could you support me?
Ngoc Son
Autodesk User
Message 15 of 17
ngocson8335
I tried to use Inventor 2019 but I can not get the size of a part with UCS1 (User UCS). Please view my attached file
Here is your code and my code:
SyntaxEditor Code Snippet
 oDef = partDoc.ComponentDefinition
'get 3d solid
			sb = oDef.SurfaceBodies.Item(1)
			'MsgBox (sb.ComponentDefinition.SurfaceBodies.Count)
			'MsgBox (partDoc.ComponentDefinition.UserCoordinateSystems.Count)
            Dim mat As Matrix
            mat.Invert()
                Dim p As Point
				p = vert.Point
                p.TransformBy(mat)
                vPoints.Add(p)
            Next
'			MessageBox.Show(minPoint.Z, "Title")
If partDoc.ComponentDefinition.SurfaceBodies.Count > 1 Then
        oPartDoc = Nothing
        Exit Sub
Dim oBox As Box
Try
        oBox = partDoc.ComponentDefinition.SurfaceBodies.Item(1).RangeBox
Catch
        iProperties.Value("Custom", "BBox_X") = ""
        iProperties.Value("Custom", "BBox_Y") = ""
        iProperties.Value("Custom", "BBox_Z") = ""
        oPartDoc = Nothing
        Exit Sub
End Try
Dim Lenght As String
Dim Width As String
Dim Height As String
Lenght = FormatNumber(oBox.MaxPoint.X - oBox.MinPoint.X, 1) & " cm"
Width = FormatNumber(oBox.MaxPoint.Y - oBox.MinPoint.Y, 1) & " cm"
Height = FormatNumber(oBox.MaxPoint.Z - oBox.MinPoint.Z, 1) & " cm"
MessageBox.Show(Lenght & " x " & Width & " x " & Height, "Size of Part")
oPartDoc = Nothing
Ngoc Son
Autodesk User
Message 16 of 17
JamieVJohnson2
So you have the confusion of how to calculate the distance between two points, and which method to use.  Think of it like this:
1.  If you use the method your code shows, where you break down 2 points into their 3 components (x,y,z) and then calculated the total distance, you will definitely get a ORIGIN based bounding box.
2.  If you use a different method (point1.distanceto(point2)), you will get a direct calculation between two points.
Since your two points are in 3D space, you want to get distances from 2 dimensions, you need to create points that eliminate the third dimension per 'work plane' of interest.  Example:
dim pXYMin as point = tg.createpoint(minPoint.x,minpoint,x,0) 'see we only drop the z value
dim pXYMax as point = tg.createpoint(maxPoint.x,maxpoint.y,0)
dim distXY as double = pxymin.distanceto(pxymax)
'repeat for yz, and xz where you drop the x value then the y value.
Message 17 of 17
JamieVJohnson2
Also since your box is rotated per ucs1 in 3d space, you have two options:
1.  Trigonometry (turn the diagonal flat plane line into a right triangle equation to get the length and with)
2.  You could attempt to get the values Before we transform them BACK to origin ucs.
In fact if getting bounding lengths is you goal, then the second option is probably the easiest for your situation.
