BOMRow.ComponentDefinitions(1).ReferenceComponents.DerivedPartComponents
shastu
Advisor Advisor
shastu
I need to export out all the part(s) that go into a derived part into an excel spreadsheet.  I already am exporting what I need from the BOM and putting it into an excel spreadsheet but it doesn't catch anything below a derived part.  If it is derived from a part, I would just need the part, but if it is a derived assembly, I need the entire structure of the assembly.  Someone suggested using this:
I don't know enough yet to understand how I can use this to accomplish what I need, can someone help?
This is what I have so far:
Sub BOM_Export()
    Dim oApp As Application
    Set oApp = ThisApplication
    If oApp.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
        Dim oAssyDoc As AssemblyDocument
        Set oAssyDoc = oApp.ActiveDocument
        Dim oAssyCompDef As AssemblyComponentDefinition
        Set oAssyCompDef = oAssyDoc.ComponentDefinition
        'Dim excel_app As Excel.Application
        ' Create the Excel application.
        Set excel_app = CreateObject("Excel.Application")
        ' Uncomment this line to make Excel visible.
        excel_app.Visible = True
        'Create new workbook
        Call excel_app.Workbooks.Add
        Dim oBomR As BOMRow
        Dim oBOMPartNo As String
        Dim oBomComments As String
Dim odoc As Document
Set odoc = ThisApplication.ActiveDocument
Dim oPropSet As PropertySet
Set oPropSet = ThisApplication.ActiveDocument.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}")
Dim oProp As Property
Set oProp = oPropSet.Item("Comments")
    Dim sProp As String
         sProp = Right(odoc.FullFileName, Len(odoc.FullFileName) - InStrRev(odoc.FullFileName, "\"))
        ' This strips off the last 4 digits of the filename.
        sProp = Left(sProp, Len(sProp) - 4)
        With excel_app
            .Range("A:A").ColumnWidth = 20
            .Range("B:B").ColumnWidth = 20
            .Range("A1").Select
            .ActiveCell.Value = "Part Number"
            .Range("B1").Select
            .ActiveCell.Value = "Copied From"
            .Range("A2").Select
            .ActiveCell.Value = sProp
            .Range("B2").Select
            .ActiveCell.Value = oProp.Value
    Dim ad As AssemblyDocument
    Set ad = ThisApplication.ActiveDocument
    Dim acd As AssemblyComponentDefinition
    Set acd = ad.ComponentDefinition
    Dim bom As bom
    Set bom = acd.bom
    ' Enable both Structured View and PartOnlyView
    bom.StructuredViewEnabled = True
    bom.StructuredViewFirstLevelOnly = False
    bom.PartsOnlyViewEnabled = True
            'Iterate through parts only BOM View
            Dim i As Integer
            For i = 1 To oAssyCompDef.bom.BOMViews(3).BOMRows.Count
                'Set oBomR to current BOM Row
                Set oBomR = oAssyCompDef.bom.BOMViews(3).BOMRows(i)
                'Get Current Row part number from part
                oBOMPartNo = oBomR.ComponentDefinitions(1).Document.PropertySets(3).ItemByPropId(5).Value
                'Get Current comments from BOM
                oBomComments = oBomR.ComponentDefinitions(1).Document.PropertySets.Item("Summary Information").Item("Comments").Value
                'Write values to spreadsheet
                i = i + 1
                .Range("A" & i + 1).Select
                .ActiveCell.Value = oBOMPartNo
                .Range("B" & i + 1).Select
                .ActiveCell.Value = oBomComments
                i = i - 1
           Next i
        excel_app.ActiveWorkbook.Saveas FileName:="C:\Users\ShaStu\Documents\" & sProp & ".xlsx"
        excel_app.Workbooks.Close
        excel_app.Quit
        End With
End Sub
adam.nagy
Autodesk Support
Autodesk Support
Yes, through that property you should be able to find out which file (in this case assembly) the part was derived from.
Then you can just read all the components of the assembly.
Cheers,
Adam Nagy
Autodesk Platform Services
MechMachineMan
Since it's Christmas season... I rehashed all of your code to something that's workable. Take care to notice how the progression of declarations of variables work, and PLEASE read up on what assigning a value to an object is.
In your old code that I reworked, you had several lines assigning the same object to different variables, just using different wording each time.
Also noticed how I split it up into multiple subs. When creating a new object this is often good practice so that the code is cleaner and errors can be handled easier to ensure the created objects are properly released from memory.
You will notice if/when you tweak this that if the excel_app object isn't run during a debug run, it will leave an EXCEL.exe active in the task manager that will have to be force-closed by ending the process via task manager.
Did some debugging on it as well, so it should definitely be working.
'Ensure this macro has Microsoft excel added as a reference
'Putting this up here outside of both subs allows us to use it globally.
Dim xlws As Excel.WorkSheet
Sub BOM_Export()
Dim oApp As Inventor.Application
If oApp.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
Call MsgBox("Active File is not Assembly. Aborting Rule")
Dim xlwb As Excel.WorkBook
Set xlwb = excel_app.Workbooks.Add
Set xlws = xlwb.Worksheets(1)
xlws.Range("A:A").ColumnWidth = 20
xlws.Range("B:B").ColumnWidth = 20
xlws.Range("A1").Value = "Part Number"
xlws.Range("B1").Value = "Copied From"
Dim oDoc As AssemblyDocument
Set oDoc = oApp.ActiveDocument
Call ProcessPartsOnlyBOM(oDoc)
sProp = oDoc.PropertySets(3).ItemByPropId(5).Value
xlwb.SaveAs FileName:="C:\Users\ShaStu\Documents\" & sProp & ".xlsx"
xlwb.Close
excel_app.Quit
Set xlwb = Nothing
Set xlws = Nothing
Set excel_app = Nothing
MsgBox ("Rule Complete!")
End Sub
'By making this private, it won't appear to click as a macro, which we want since it would error out since it doesn't generate it's own instance of xlws
Private Sub ProcessPartsOnlyBOM(oDoc As Document)
Dim oBOM As BOM
Set oBOM = oDoc.ComponentDefinition.BOM
' oBOM.StructuredViewEnabled = True
' oBOM.StructuredViewFirstLevelOnly = False
oBOM.PartsOnlyViewEnabled = True
Dim oPartsOnlyBOM As BOMView
Set oPartsOnlyBOM = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow As BOMRow
' j will be our counter to track which row in excel we are writing to.
Dim j As Integer
j = 2
For i = 1 To oPartsOnlyBOM.BOMRows.Count
Set oBOMRow = oPartsOnlyBOM.BOMRows(i)
'This row causes the rule to skip every BOMRow that isn't for a part file.
If oBOMRow.ComponentDefinitions(1).Type <> 83886592 Then 'ObjectTypeEnum.kPartComponentDefinition
xlws.Cells(j, 1).Value = "SKIPPED BOM ROW"
j = j + 1
GoTo SkipRow
Set oBOMRowDoc = oBOMRow.ComponentDefinitions(1).Document
xlws.Cells(j, 1).Value = "Hi"
xlws.Cells(j, 1).Value = oBOMRowDoc.PropertySets("Design Tracking Properties")("Part Number").Value
xlws.Cells(j, 2).Value = oBOMRowDoc.PropertySets.Item("Summary Information").Item("Comments").Value
j = j + 1
If oBOMRow.ComponentDefinitions(1).ReferenceComponents.DerivedPartComponents.Count > 0 Then
For Each oDerivedpartComponent In oBOMRow.ComponentDefinitions(1).ReferenceComponents.DerivedPartComponents
xlws.Cells(j, 1).Value = "DERIVED PART"
xlws.Cells(j, 2).Value = oDerivedpartComponent.ReferencedDocumentDescriptor.FullDocumentName()
j = j + 1
Next
SkipRow:
If Err.Number <> 0 Then
Call MsgBox("Issues accessing BOM row document! May be a virtual part row. Need extra coding to handle these")
Err.Clear
Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Owner2229
You're missing the exiting part of the document check.
Exit Sub
 Also globals sould be defined as one of these (it depends on if you want to acces them from other modules/classes):
Private xlws As Excel.WorkSheet
Public xlws As Excel.WorkSheet
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
MechMachineMan
Good catch!
Guess I should probably quit coding up until midnight and give my brain a rest.
Repaired code:
Sub BOM_Export()
Exit Sub End If Dim excel_app As Excel.Application Set excel_app = CreateObject("Excel.Application") excel_app.Visible = True Dim xlwb As Excel.WorkBook Set xlwb = excel_app.Workbooks.Add Set xlws = xlwb.Worksheets(1) xlws.Range("A:A").ColumnWidth = 20 xlws.Range("B:B").ColumnWidth = 20 xlws.Range("A1").Value = "Part Number" xlws.Range("B1").Value = "Copied From" Dim oDoc As AssemblyDocument Set oDoc = oApp.ActiveDocument Call ProcessPartsOnlyBOM(oDoc) sProp = oDoc.PropertySets(3).ItemByPropId(5).Value xlwb.SaveAs FileName:="C:\Users\ShaStu\Documents\" & sProp & ".xlsx" xlwb.Close excel_app.Quit Set xlwb = Nothing Set xlws = Nothing Set excel_app = Nothing MsgBox ("Rule Complete!") End Sub 'By making this private, it won't appear to click as a macro, which we want since it would error out since it doesn't generate it's own instance of xlws Private Sub ProcessPartsOnlyBOM(oDoc As Document) Dim oBOM As BOM Set oBOM = oDoc.ComponentDefinition.BOM ' oBOM.StructuredViewEnabled = True ' oBOM.StructuredViewFirstLevelOnly = False oBOM.PartsOnlyViewEnabled = True Dim oPartsOnlyBOM As BOMView Set oPartsOnlyBOM = oBOM.BOMViews.Item("Parts Only") Dim oBOMRow As BOMRow ' j will be our counter to track which row in excel we are writing to. Dim j As Integer j = 2 For i = 1 To oPartsOnlyBOM.BOMRows.Count Set oBOMRow = oPartsOnlyBOM.BOMRows(i) 'This row causes the rule to skip every BOMRow that isn't for a part file. If oBOMRow.ComponentDefinitions(1).Type <> 83886592 Then 'ObjectTypeEnum.kPartComponentDefinition xlws.Cells(j, 1).Value = "SKIPPED BOM ROW" j = j + 1 GoTo SkipRow End If Set oBOMRowDoc = oBOMRow.ComponentDefinitions(1).Document xlws.Cells(j, 1).Value = "Hi" xlws.Cells(j, 1).Value = oBOMRowDoc.PropertySets("Design Tracking Properties")("Part Number").Value xlws.Cells(j, 2).Value = oBOMRowDoc.PropertySets.Item("Summary Information").Item("Comments").Value j = j + 1 If oBOMRow.ComponentDefinitions(1).ReferenceComponents.DerivedPartComponents.Count > 0 Then For Each oDerivedpartComponent In oBOMRow.ComponentDefinitions(1).ReferenceComponents.DerivedPartComponents xlws.Cells(j, 1).Value = "DERIVED PART" xlws.Cells(j, 2).Value = oDerivedpartComponent.ReferencedDocumentDescriptor.FullDocumentName() j = j + 1 Next End If SkipRow: If Err.Number <> 0 Then Call MsgBox("Issues accessing BOM row document! May be a virtual part row. Need extra coding to handle these") Err.Clear End If Next End Sub
Justin K
