Hi
If a user opens a BOM. What is the command to select all?
I will be writing some code to after this select all is run. It then copies the selection, opens excel and pastes into excel.
This is due to the fact that we only want the user to expand the assemblies that are required to be in the BOM. e.g. an off the shelf purchase of a cylinder does not require all parts to be purchased, only the cylinder itself.
Another option is replace the assembly of the cylinder as a derived part file, but this will not allow driving constraints. So this will not work.
Our customer is not using Item Master unfortunately.
Thanks for any help
Paul
