BOM part number edit within .iam not staying applied
I have an assembly file which I am trying to modify the part numbers on. The way I usually do this is by opening the BOM within the .iam and then clicking in the "part number" cell and changing ti to what I what it to be. I also do this for the description cells too. I then press done, hit save and the .iam's and .ipt's of my top level assembly will be updated as per the BOM edits I have made
I am now using Inventor 2018 and I am trying this exact process and it does not seem to be working. It allows me the edit the part number cells and descriptions but does retain these edits after I press done and save. It seems to be a problem related to this particular .iam model as I did a test on a basic assembly and the method described above worked fine?
Any help would be greatly appreciated
MechMachineMan
I have a co-worker who is also running into this issue.
Mroe specifically, he is trying to change thing in the PartsOnly BOM, and after the cells are change, as soon as exit is pressed, next time the BOM is opened, things do no have the fields filled in.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
JaneFan
Hello @Anonymous and @MechMachineMan,
Sorry for the inconvenience.
This is a known issue in inventor 2018 because of Dev Expres upgrade which happens when BOM view list is long enough to show scroll bar.
The issue was fixed and will be included in near release. Before that, I have a not-so-good interim work around: Enlarge BOM dialog enough to make sure the row still shows in the active view after name change.
Jane Fan
Inventor/Fusion QA Engineer
sschulteH6WZ3
Any idea when this will be released? I would have to have a monitor that is 3 ft tall to get the whole BOM in the same window. I guess short of an extra large monitor the laborious and time eating work of opening and changing the iproperties for each part will have to be done. But hey my employer does not mind eating the cost of y'alls screw up said no employer ever.
JaneFan
It will be released very soon. Please keep an eye on update information in Autodesk Desktop App.
Jane Fan
