BOM in order as in the feature tree, Images to Excel document
checkcheck_master
checkcheck_master
I would like to have a BOM based on the order as in the Feature Tree.
Does anyone know if such a thing is available?
Asked differently, I manage to get the Feature Tree to a txt file based on the sequence.
To Excel should also work, but I don't know how to get the images to Excel.
Does anyone know how to bring the images, including the Assembly itself, to Excel?
theo.bot
Would a Structure BOM view with "all level" give you the list you want?  If the Thumbnail column is included this will be exported to excel.
checkcheck_master
Thanks Theo for your reaction.
I would like to have the BOM ordered as it is in the Browser Tree.
With the BOM export option this doesn't work so well.
Hence the question how the images can be brought to an Excel column
I would also like to have a BOM that can show absolute quantities.
Any suggestions are more then welcome.
asE47S8
I recently wrote a VBA script to export the BOM of the currently open assembly or drawing in Inventor 2023. This script grabs the currently active file you have open in Inventor, where after goes through all underlying subassemblies and parts. It uses the inventor object library to access your inventor instance. I dont know how to get the images out, but this atleast captures the structure of the BOM
Im sadly not able to share a real example because of my NDA, but ive made an example with placeholder data:
If you'd like to take a look at this, then see the code below:
If you are using vault, it'll ask you to check out all underlying parts. Here the script will still work with simply clicking "No to all" and then not saving the changes made to the files. Be aware of line 160, where i use formulalocal. This is because im working with danish excel function names. If you choose to use this code then remember to change this line to your local language or english excel syntax. (gentag means repeat in english).  This formula will show the assembly in a hierarcal view, just like the browser tree.
Option Explicit
' A global (or module-level) collection to keep track of assemblies visited
Dim visitedAssemblies As Collection
Public Sub GenerateRecursiveBOMFromActiveInventorAssemblyV2()
    Dim invApp As Inventor.Application
    ' Attempt to connect to a running Inventor instance
    On Error Resume Next
    Set invApp = GetObject(, "Inventor.Application")
    On Error GoTo 0
    If invApp Is Nothing Then
        ' Keep here in case id like to force open inventor later.
        ' Set invApp = CreateObject("Inventor.Application")
        ' invApp.Visible = True
        MsgBox "Inventor was not running. Please open a valid top level assembly and try again"
        ' A new instance has started. " & vbCrLf & _
        ' "Please open an assembly in Inventor and re-run the macro.", vbInformation
        Exit Sub
    End If
    Dim oDoc As Inventor.Document
    Set oDoc = invApp.ActiveDocument
    If oDoc Is Nothing Then
        MsgBox "No active document in Inventor.", vbExclamation
        Exit Sub
    End If
    ' Check if the user has a
    If oDoc.DocumentType <> kAssemblyDocumentObject Then
        If oDoc.DocumentType = kDrawingDocumentObject Then
            ' MsgBox "This is a drawing, here it should change the focused document to the attached assembly"
            If oDoc.ReferencedDocuments.Item(1).DocumentType = kAssemblyDocumentObject Then
                Set oDoc = oDoc.ReferencedDocuments.Item(1)
                ' MsgBox "Great success, this found the right assembly: " + oDoc.ReferencedDocuments.Item(1).PropertySets("Design Tracking Properties").Item("Part Number").value
            End If
         Else
            Exit Sub
         End If
    End If
    Dim oAsmDoc As Inventor.AssemblyDocument
    Set oAsmDoc = oDoc
    ' Get a clean name for the new sheet from the assembly
    Dim asmName As String
    asmName = Replace(oAsmDoc.DisplayName, ".iam", "", , , vbTextCompare)
    asmName = SafeSheetName(asmName)
    ' Create a new sheet named after the assembly
    Dim ws As Worksheet
    Set ws = ActiveWorkbook.Worksheets.Add
    ws.Name = asmName
    If Err.Number <> 0 Then
        ' If there's a naming conflict or invalid name, revert to a default name
        Err.Clear
        ws.Name = "Assembly_BOM"
    End If
    On Error GoTo 0
    ' Prepare visited assemblies collection to avoid loops
    Set visitedAssemblies = New Collection
    ' Set up headers
    With ws
        .Cells.ClearContents
        .Range("A1").value = "Level"
        .Range("B1").value = "Item Number"
        .Range("C1").value = "Part Number"
        .Range("D1").value = "Description"
        .Range("E1").value = "Quantity"
        .Range("F1").value = "Document Name"
    End With
    Dim currentRow As Long
    currentRow = 2
    ' Recursively process the BOM
    WriteBOMRecursive oAsmDoc, ws, currentRow, 0
    MsgBox "Full recursive BOM created on new sheet '" & ws.Name & "'.", vbInformation
    ' Call SymmetricDifference.FindSymmetricDifference(asmName)
End Sub
' Recursively explore sub-assemblies, writing BOM info to Excel
Private Sub WriteBOMRecursive( _
    ByVal oAsmDoc As Inventor.AssemblyDocument, _
    ByVal ws As Worksheet, _
    ByRef currentRow As Long, _
    ByVal level As Long)
    Dim formulaStr As String
    Dim asmKey As String
    asmKey = LCase(oAsmDoc.FullFileName)
    ' Skip if we’ve visited it before (avoid infinite loops)
    Dim visited As Variant
    For Each visited In visitedAssemblies
        If visited = asmKey Then
            Exit Sub
        End If
    Next visited
    ' Mark this assembly as visited
    visitedAssemblies.Add asmKey
    ' Get the BOM and configure
    Dim oBOM As Inventor.BOM
    Set oBOM = oAsmDoc.ComponentDefinition.BOM
    oBOM.StructuredViewEnabled = True
    oBOM.StructuredViewFirstLevelOnly = False
    ' If available, you might try: oBOM.StructuredViewMerged = False
    Dim oBOMView As Inventor.BOMView
    Set oBOMView = oBOM.BOMViews.Item("Structured")
    Dim oRow As Inventor.BOMRow
    For Each oRow In oBOMView.BOMRows
        If oRow.ComponentDefinitions.Count = 0 Then GoTo SkipRow
        Dim cDef As Inventor.ComponentDefinition
        Set cDef = oRow.ComponentDefinitions.Item(1)
        Dim rowDoc As Inventor.Document
        Set rowDoc = cDef.Document
        ' Fetch iProperties
        Dim PartNumber As String
        Dim description As String
        PartNumber = rowDoc.PropertySets("Design Tracking Properties").Item("Part Number").value
        description = rowDoc.PropertySets("Design Tracking Properties").Item("Description").value
        On Error GoTo 0
        ' Write the row data
        With ws
            .Cells(currentRow, 1).value = level
            .Cells(currentRow, 2).value = oRow.ItemNumber
            .Cells(currentRow, 3).value = PartNumber
            .Cells(currentRow, 4).value = description
            .Cells(currentRow, 5).value = oRow.ItemQuantity
            .Cells(currentRow, 6).value = rowDoc.DisplayName
            ' .Offset(0, 0) is used to convert from .Cells object to .Range object
            .Cells(currentRow, 7).Offset(0, 0).FormulaLocal = "=GENTAG(""    ""; A" + CStr(currentRow) + ")" + "& C" + CStr(currentRow)
        End With
        currentRow = currentRow + 1
        ' If this is a sub-assembly, recurse down
        If rowDoc.DocumentType = kAssemblyDocumentObject Then
            WriteBOMRecursive rowDoc, ws, currentRow, level + 1
        End If
SkipRow:
    Next oRow
    With ws
        .Columns("C").NumberFormat = "0000000"
        .Columns("A:I").AutoFit
    End With
End Sub
' Sanitize a string for use as an Excel worksheet name
' Excel sheet names have a 31-character limit and cannot contain certain symbols
Private Function SafeSheetName(ByVal rawName As String) As String
    Dim tmp As String
    tmp = Trim(rawName)
    ' Remove illegal characters: \ / ? * [ ] : etc.
    ' We'll just remove them here
    Dim illegalChars As Variant
    illegalChars = Array("\", "/", "?", "*", "[", "]", ":", "'")
    Dim ch As Variant
    For Each ch In illegalChars
        tmp = Replace(tmp, ch, "")
    Next ch
    ' Also, sheet name cannot exceed 31 chars
    If Len(tmp) > 31 Then
        tmp = Left(tmp, 31)
    End If
    ' Edge case: if name is blank, default to something
    If tmp = "" Then
        tmp = "AssemblyBOM"
    End If
    SafeSheetName = tmp
End Function
This script was written to compare Inventors BOM with our ERP system for data validation. If you are interested in doing something simmilar, ive got a couple more tricks for doing this. 🙂
Hope this helps,
-Anders
