BOM export from bill of material windows versus bom.export from code?
mucip
mucip
I arranged all coulms of Bill of Material list from own window. I am using "sav as" dialog box and csv option. But when I do this from the vba or vb.net below code:
oStructuredBOMView.Export(FileNameCsv, FileFormatEnum.kTextFileCommaDelimitedFormat)
The written csv file coulmn design is not like first step... This is very interesting.
The both file should be same, shouldn't it?!...
Mucip:)
skyngu
it is not the same since inventor 2011. autodesk has not fixed it.
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/export-bom-with-different-order/m-p/31...
Autodesk Inventor Professional 2019
mucip
Thanks a lot... Well how can we solve this problem until Autodesk will fix it? Can we export BOM with the VB.NET code line by line to the csv or xls file?...
And ofcourse how can we apply press on Autodesk to solve this problem?...
Mucip:)
Mark_Wigan
yes it would be nice to get this bom export topic sorted.
ps- i recall some people submitting various requests to improve the functionality of inventor's BOM export capabilities, but possibly not the API side of the topic.
it would perhaps be worth checking over on the IdeasStation part of the various forums if you want to log a new idea or add kudos to any worthwhile existing idea that have been submitted.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
