BOM - Count Instances of Items
arkelec
arkelec
I know how to configure a part so that the length data is exported & appears in a BOM (Unit QTY) & is summarised to a sub-total (QTY).
What I want to do is add another column which will count the instances of each line, so that it will show 2 nº for line 1, 3 nº for line 2 & 1 nº for line 3.
1st Q: it is possible?
2nd Q: is it relatively easy?
I can (just about) follow the simpler VB coding.  I assume that if it's possible, I'd need to create a ILogic rule & embed that into template(s)?
HermJan.Otterman
no need for programming, just add the "Item QTY" to the BOM (Choose Columns)
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
arkelec
Oh FFS, now I feel like a right berk.
Thanks for the quick reply @HermJan.Otterman.
