Assembly Copy Components using ilogic, unique numbering
nico
nico
Ellowah
I was wondering if any1 knows a way to automate the Copy Components function in an Assembly with ilogic
Basicly I want to Add a prefix to all subassembly's And PARTS so I have a complete unique fileset
Edit the Source Location to a new, potentially not excisting, folder
Kind Regards,
Nico Van Donick
HermJan.Otterman
did you try the "iLogic Design Copy"?
open Inventor, do not open any file!
go to Tools, iLogic, iLogic Design Copy
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
marcin_otręba
Check this code... you must for example create some form with 3 text boxes prefix, new_path and assembly new name...
Sub rename()
ThisApplication.SilentOperation = True
Dim ass As AssemblyDocument
Set ass = ThisApplication.ActiveDocument
Dim doc As Document
ass.SaveAs new_path & new_ass_name & Right(doc.FullFileName, 4), False
For Each doc In ass.AllReferencedDocuments
dim new_name as string = prefix & doc_oldname
doc.SaveAs new_path & new_name & Right(doc.FullFileName, 4), False
Next
ass.Save
ThisApplication.SilentOperation = False
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
