SolidBody visibility
Hi everyone,
Here is my rule in ilogic,
'catch and skip errors
On Error Resume Next
'define the active assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'define Sb as solidbodies
Dim SB As SurfaceBody
'define ShellB as a surfacebodies
Dim ShellB As WorkSurface
'define Vis and Vis2 as boolean type
Dim Vis As Boolean
Dim Vis2 As Boolean
'choose solid or surface bodies
If solidOrShell = "Solid" Then
	Vis = True
	Vis2 = False
Else If solidOrShell = "Shell" Then
	Vis = False
	Vis2 = True
Dim oDoc As Inventor.Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
    For Each SB In oDoc.ComponentDefinition.SurfaceBodies
        SB.Visible = Vis
    Next
	For Each ShellB In oDoc.ComponentDefinition.WorkSurfaces
		ShellB.Visible = Vis2
		Next
Next
ThisApplication.ActiveDocument.Update
after i changed solid body to surface I would like to leave some elements as solid.
How can i do this ?
KS
What criteria do you want to filter by?
You can filter them out in your For loop.
'For Each oDoc in oAssyDoc.AllReferencedDocuments
If somecriteria = True Then
         SB.Visible = Vis
     Next
        Next
Next
the for loop is a good solution.
but I am looking for a simpler solution.
as here in the assembly I want to change the visibility SB in "bMainStrop" part
I'm looking for a solution something like this
SyntaxEditor Code Snippet
Feature.IsActive("Part1:1", "featurename")
Here is a solution, but if somebody can do it easier please show us your code 🙂
Dim Vis As Boolean
Dim Vis2 As Boolean
'define parts name
Dim gniazdo1 As String
gniazdo1 = "gniazdo1.ipt"
Dim gniazdo1_MIR As String
gniazdo1_MIR = "gniazdo1_MIR.ipt"
Dim gniazdo As String
gniazdo = "gniazdo.ipt"
Dim gniazdo_MIR As String
gniazdo_MIR = "gniazdo_MIR.ipt"
    Vis = True
    Vis2 = False
    Vis = False
    Vis2 = True
'   define name of part
    Dim FNamePos As Long
    FNamePos = InStrRev(oDoc.FullFileName, "\", -1)
    Dim docFName As String
    docFName = oDoc.FullFileName
    docFName = Right(oDoc.FullFileName, Len(oDoc.FullFileName) - FNamePos)
'   verify condition
     If gniazdo = docFName Or gniazdo_MIR = docFName Or gniazdo1 = docFName Or gniazdo1_MIR = docFName Then
            SB.Visible = True
        Next
    Else
            SB.Visible = Vis
        Next
        Next
Next
KS
