Balloons
Balloons
wfisher
Message 1 of 10
Balloons
wfisher
This code will find the balloon #10 fine.
How wiil the code be modifiedI if I were looking to find # 9?
See attached Pic
Public Sub Findballoon()
Dim oDrawing As DrawingDocument
Set oDrawing = ThisApplication.ActiveDocument
Dim osheet As Sheet
Set osheet = oDrawing.ActiveSheet
Dim oBalloon As Balloon
For Each oBalloon In osheet.Balloons
If oBalloon.BalloonValueSets(1).value = "10" Then
MsgBox "Found it"
Else
End If
Next oBalloon
End Sub
Thanks Wayne
Replies (9)
Message 2 of 10
Public Function Findballoon(Number As String) As Boolean
Dim osheet As Sheet
If oBalloon.BalloonValueSets(1).value = Number Then Findballoon = True
Next oBalloon
End Sub
Joe ...
wrote in message news:5793370@discussion.autodesk.com...
See attached Pic
Dim osheet As Sheet
MsgBox "Found it"
Else
End If
Next oBalloon
End Sub
Thanks Wayne
Message 3 of 10
Oops, I guess I should have supplied an example of using the function?
If Findballon("9") then
MsgBox "Found it ..."
End If
Joe ...
"Joe Sutphin" wrote in message
news:5793379@discussion.autodesk.com...
Dim osheet As Sheet
Next oBalloon
End Sub
Joe ...
See attached Pic
Dim osheet As Sheet
MsgBox "Found it"
Else
End If
Next oBalloon
End Sub
Thanks Wayne
Message 4 of 10
That won't work. You also need to cycle through ALL the
BalloonValueSets of the Balloon. Because #9 is in BalloonValSets(3).Value
Also you need to change your end statement
> Next oBalloon
> End Sub
Message 5 of 10
Huh? End statement?
"Bob S." wrote in message
news:5793384@discussion.autodesk.com...
> Next oBalloon
> End Sub
Message 6 of 10
That's what I get for writing on the fly.
The "End Sub" would changed automatically in the IDE.
But there was another correction. There should be an Exit Function inside
the For loop.
Joe ...
news:5793415@discussion.autodesk.com...
Huh? End statement?
> Next oBalloon
> End Sub
Message 7 of 10
wfisher
Thanks for the replies all! I have another question.
How do I find the postion of balloon number 10
oBalloon.BalloonValueSets(4).value = "10"
This statement will only find the first balloon
(oBalloon.Position.x, oBalloon.Position.y)
I am trying to get the red circle around balloon number 10
Any ideas?
Wayne
Message 8 of 10
Looks like you would also have to examine the
oBalloon.PlacementDirection, somehow find the
size of the circle, multiply that by the position
(BalloonValueSet index #) of your balloon and add
that value to your original x or y positions
(dependent on direction).
Bob S.
> Any ideas?
> Thanks
> Wayne
Message 9 of 10
wfisher
Thanks Bob,
Will do!!
Wayne
Message 10 of 10
Hi All
This code sounds like it may sort of do what I am looking for.
On Multi Sheet drawings we have a column in the BOM that identifies what sheet and zone each item is first ballooned. We are looking to try and automate this task since it is some what time consuming, and can often get out of date as the drawing is being developed.
Has anyone done this short of thing, or do you think it is possible?
Cheers
Mike
