Avoid Old version pop on save
HI all,
how to avoid pop up when saving an inventor file from a previous version?
Tryied
ThisApplication.Silent
ThisApplication.UserInterfaceManager.UserInteractionDisabled = False
but seems is not working.
Thanks, regards
Massimo
Rob67ert
That would be a great to ave that fixed.
Every new release we have the same problem.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
MechMachineMan
Try:
ThisApplication.SilentOperation = True
and dont forget to turn it off before the end of your code / before it quits if it errors out.
ThisApplication.SilentOperation = False
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
