Automatic Drawing Creation
abrennerH3RF2
Observer Observer
abrennerH3RF2
Observer
Observer
I'm new to using Autodesk Inventor as of 3 months ago, I am not exploring ways to use iLogic to speed up drawings creation, we are a composites manufacturing company. Each assembly has 6 to 7 layers of fiberglass and foam that would need to have sketch associated with it in the assembly file showing the layout of the fiberglass pieces.
I have tried using ChatGPT to write VBA code for iLogic but i fear the complexity of the task I'm asking is outside of it's scope to perform correctly.
Are there other time saving short cuts the community could share with me?  Any useful ideas would be appreciated.
ryan.rittenhouse
Tips for automating drawings are going to vary depending on what you are doing with it. Can you post some examples of what you are working with and what kind of result you are looking to get w/ iLogic?
If this solved your problem, or answered your question, please click Accept Solution.
BM_Ashraf
Hi @abrennerH3RF2 ,
Maybe this tool can boost your drawing creation process. it has also a customizable iLogic section, that allows you to add ilogic rules upon the process of the Add-in
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=1807220202761767197&appLang=en&os=Win64
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
