Automatic add rule
Automatic add rule
ChristianAndersenIsmyname
Message 1 of 8
Automatic add rule
Is it possible to make a external rule that adds rules to a file?
For example:
I have some newly made rules in my .iam and .ipt template that I want to add to existing parts/assemblys. Can I somehow make a external rule that does something like:
iLogicVb.AddRule("Template.iam", "Find Part")         '-- Notice AddRule instead of RunRule
iLogicVb.AddRule("Template.iam", "Write")
'-- etc
The same thing for forms. I know I can copy and paste forms, but it would be easier to do this within the same external rule.
Or would my best way to achieve this be template swap on existing parts?
Replies (7)
Message 2 of 8
JhoelForshav
Hi @ChristianAndersenIsmyname
I haven't tried it but I think something like this should work? 🙂
Sub CopyRule(copyFromDoc As Document, oRuleName As String, CopyToDoc As Document)
	Dim oRuleText As String = iLogicVb.Automation.GetRule(CopyFromDoc, oRuleName).Text
	iLogicVb.Automation.AddRule(CopyToDoc, oRuleName, oRuleText)
End Sub
Message 3 of 8
Hi Jhoel,
I can't get your code to work. Is it iLogic or VBA?
I've tried to "fix" it, and the closest I've come to is this:
	Dim CopyFromDoc As String
	Dim CopyToDoc As String
	Dim oRuleName As String
	CopyFromDoc = "K:\04. R&D\3D MODELING\STYLES\Templates\Standard.iam" 'Template
	CopyToDoc = ThisDoc.PathAndFileName(False)
	oRuleName = "Write"
	oRuleText = iLogicVb.Automation.GetRule(CopyFromDoc, oRuleName).Text
I had to change Copyfromdoc as document → string. It stopped at this sentance if it was document.
Now it stops at "oRuleText", which I believe is caused by Copyfromdoc is not a document.
Message 4 of 8
JhoelForshav
It's a sub that I thought you can use in ilogic. Like this maybe?
Sub Main
Dim ruleDoc As Document = ThisApplication.Documents.Open("K:\04. R&D\3D MODELING\STYLES\Templates\Standard.iam", False)
CopyRule(ruleDoc, "Write", ThisDoc.Document)
End Sub
End Sub
Message 5 of 8
This works perfectly! Thank you.
Is it possible to make a same one for Forms?
Message 6 of 8
JhoelForshav
Sorry @ChristianAndersenIsmyname , I don't think thats possible.
It's been discussed before here:
https://forums.autodesk.com/t5/inventor-forum/copy-ilogic-form-via-api-to-several-documents/td-p/543...
And it seems like the way to go is global forms...
Message 7 of 8
Ah ****. Thanks for you help anyway! 🙂
Message 8 of 8
robertast
so it is convenient to copy the form without a rule
