Automate ipart flat pattern export to dxf
dan_goodrich89
dan_goodrich89
I'm trying to modify Clint Browns Automate DXF Flat Patterns iLogic code to run through all ipart members and export dxfs https://clintbrown.co.uk/2018/12/09/dxf/
It works on the active iPart, adjusting the code to name the dxf using the ipart number, but I'm struggling with looping it though all iPart members.
JelteDeJong
does this work for you?
Dim doc As PartDocument = ThisDoc.Document
If (doc.ComponentDefinition.IsiPartFactory = False) Then
    MsgBox("This is not an iPart factory")
Dim fact As iPartFactory = doc.ComponentDefinition.iPartFactory
For Each row As iPartTableRow In fact.TableRows
    fact.DefaultRow = Row
    doc.Update()
    doc.Update2(False)
    Dim oCompDef As SheetMetalComponentDefinition = doc.ComponentDefinition
    If oCompDef.HasFlatPattern = False Then
        oCompDef.Unfold()
    Else
        oCompDef.FlatPattern.Edit
    'DXF Settings
    Dim sOut As String
    sOut = "FLAT PATTERN DXF?AcadVersion=2000&OuterProfileLayer=IV_INTERIOR_PROFILES"
    Dim sFname As String = "c:\temp\" & ThisDoc.FileName(False) & "_" & Row.MemberName & ".dxf"
    'Export the DXF and fold the model back up
    oCompDef.DataIO.WriteDataToFile(sOut, sFname)
    oCompDef.FlatPattern.ExitEdit()
Next
Jelte de Jong
Blog: hjalte.nl - github.com
dan_goodrich89
Works perfectly, thank you!
First and foremost thank you for the great piece of code you have provided here.
I am trying to do something similar, I made a recent forum post about it, for reference:
https://forums.autodesk.com/t5/inventor-customization/ilogic-code-to-export-all-iparts-as-dxf-or-dwg...
But I tried your code on a flat pattern drawing. It went through all the iParts and seemed like it was saving it or doing something since it went through each and every single drawing, however I cannot find where these files ended up... Code ran flawlessly no errors.
aurel_e
Have you looked at   "c:\temp\" ?
KrishR330
I am trying to name the DXF file with values of few custom parameters of my iPart file instead of Row.MemberName.  Can you help change the code accordingly?
 Thanks and Regards,
Krish
floccipier
@JelteDeJong brilliant as always. thanks for this simple and effective code.
