Ilogic BOM Enabled for all child assemblies.
davis.j
davis.j
I've scoured the web and I am at a roadblock. I need help converting the following illogic code so that it applies to all child assemblies (All lower level Assemblies.)
I am not skilled at coding so any help would be appreciated. 🙂
Sub Main()
    Dim oDoc As Document
	oDoc = ThisApplication.ActiveDocument
	Dim oBOM As BOM
    oBOM = oDoc.ComponentDefinition.BOM
    For Each oDoc In ThisApplication.Documents
        If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			oBOM.StructuredViewEnabled = True
			oBOM.StructuredViewFirstLevelOnly = True
			oBOM.PartsOnlyViewEnabled = True
    Next
End Sub
dutt.thakar
@davis.j
Can you please try and see if it works. Make sure your assembly has Default BOM Structure, as this check is not covered in the code. If it has a Reference BOM Structure, it could give errors.
Sub Main()
    Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oOcc As ComponentOccurrence
    For Each oOcc In oDef.Occurrences
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Dim oODoc As AssemblyDocument = oOcc.Definition.Document
			Dim oBOM As BOM = oODoc.ComponentDefinition.BOM
    Next
End Sub
Hope this is helpful.
If this has answered your question, please accept it as a solution.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
davis.j
@dutt.thakar
Thank you,
This worked for all of the child assemblies in each lower level but it did not modify the current open assembly BOM.
I have monkey'd around it seems the following code has worked but I'm not sure if it is written in the proper notation.
Sub Main()
    Next
	Dim aBOM As BOM
    aBOM = oDoc.ComponentDefinition.BOM
	aBOM.StructuredViewEnabled = True
	aBOM.StructuredViewFirstLevelOnly = True
	aBOM.PartsOnlyViewEnabled = True
End Sub
dutt.thakar
@davis.j
yes you have written is correctly. I forgot to add that. You can either write the same first or after changing the child assembly BOM, It won't make any difference.
If my code has answered your question, please mark it as a solution.
Dutt Thakar
Dutt Thakar
LinkedIn
dutt.thakar
@davis.j
yes you have written it correctly. I forgot to add that. You can either write the same first or after changing the child assembly BOM, It won't make any difference.
Dutt Thakar
Dutt Thakar
LinkedIn
dutt.thakar
@davis.j
Yes you have written it correctly. It won't make any difference if you write first or in last. I actually forgot to add that, thought you only need fir sub assembly levels.
If my previous code has answered your question, please accept it as a solution.
Dutt Thakar
Dutt Thakar
LinkedIn
