does this work for you?
Dim doc As PartDocument = ThisDoc.Document
If (doc.ComponentDefinition.IsiPartFactory = False) Then
MsgBox("This is not an iPart factory")
End If
Dim fact As iPartFactory = doc.ComponentDefinition.iPartFactory
For Each row As iPartTableRow In fact.TableRows
fact.DefaultRow = Row
doc.Update()
doc.Update2(False)
Dim oCompDef As SheetMetalComponentDefinition = doc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold()
Else
oCompDef.FlatPattern.Edit
End If
'DXF Settings
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2000&OuterProfileLayer=IV_INTERIOR_PROFILES"
Dim sFname As String = "c:\temp\" & ThisDoc.FileName(False) & "_" & Row.MemberName & ".dxf"
'Export the DXF and fold the model back up
oCompDef.DataIO.WriteDataToFile(sOut, sFname)
oCompDef.FlatPattern.ExitEdit()
Next
Jelte de Jong
Blog: hjalte.nl - github.com
