Autodesk Inventor 2023.3 Update breaks some Add-ins
Maxim-CADman77
Advisor Advisor
Message 1 of 17
Maxim-CADman77
It was noticed that Nifty Attributes (a kind of descendant of Attribute Helper*) by @BrianEkins can not be used after updating Autodesk Inventor from 2023.2 to 2023.3 (after pressing Add-In's ribbon button the Add-In's window shows for just a moment and then closes by itself).
Part of SDK-UserTools.
UPDATE:
Nifty Attributes works fine in Inventor 2024.
Please vote for Inventor-Idea Text Search within Option Names
Replies (16)
Message 2 of 17
bradeneuropeArthur
Could you give the exact reference to what add-in you mean?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 17
Maxim-CADman77
My initial post contains hyperlink to Nifty Attributes Add-In homepage (https://ekinssolutions.com/nifty_attributes/).
Message 4 of 17
bradeneuropeArthur
Seems that this tool is already in Inventor, per default.
That is why you cannot load it twice!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 17
Maxim-CADman77
You mean that Inventor 2023 has some built-in Add-in to work with attributes ... which is not present in 2024 (see UPDATE in the 1st message of this thread)?
Message 6 of 17
bradeneuropeArthur
Not sure if it is not available in 2024. But in 2023 it is present per default.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 17
Maxim-CADman77
I believe I don't have any bulit-in Add-ins to work with Attributes in Inventor 2023.
Here is the list of add-ins built-into AI 2023 (printed with iLogic):
3d Annotation
Additive Manufacturing
Anark 3D PDF Publishing
Assembly Bonus Tools
Auto Limits
BIM Content
BIM Simplify
Content Center
Design Accelerator
Design Checker
Drag & Drop Interoperability
ESKD Support
FeedbackAddIn
Frame Generator
Fusion 360 Interoperability
iCopy
iLogic
Interactive Tutorial
Inventor Studio
Mold Design
Presentations
Routed Systems: Cable & Harness
Routed Systems: Tube & Pipe
Shared Views
Simulation: Dynamic Simulation
Simulation: Frame Analysis
Simulation: Stress Analysis
Which one conflicts with Nifty Attributes?
Message 8 of 17
bradeneuropeArthur
Can you have a look in the toolstab of inventor. For me it is there in 2023!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 17
Maxim-CADman77
Here is how Tools Tab looks for me before I install Nifty Attributes (and after I uninstall it):
Message 10 of 17
robertast
@bradeneuropeArthur   can you show me where you see it? If you are talking about the ability to assign attributes already in the inventory, then this is not the same thing
@johnsonshiue  see this looks like bug 2023.3 update
Message 11 of 17
bradeneuropeArthur
here:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 17
Maxim-CADman77
I believe you have it present because you've installed SDK-UserTools* (C:\Users\Public\Documents\Autodesk\Inventor 2023\SDK\UserTools.MSI), right?
But the main question is: whether It works as expected after installing Update 2023.3 ? (for me it doesn't - the same problem - it's window closes by itself half-second after I press the button to show it).
That's how I can get it.
Message 13 of 17
bradeneuropeArthur
This does not install the add-in if i am right. this only unpack the vb.net projects.
Did not install that. I still think it comes shipped with inventor.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 17
Mike.Wohletz
I don't know if it has anything to do with the 2023.3 updates, but I will concur that it does not work as it shows a quick flash of the dialog and then is gone. I don't have any other add-ins that do not work and that is good because I find this post when I am past the 50% mark of updating about 160 clients tonight.
Message 15 of 17
robertast
Most likely this is a problem in 2023.3 since it works again in 2024
 @CGBenner   What do you think?
Message 16 of 17
Felix-Saibel
Nifty Attributes is working fine.... many thanks!!!
Message 17 of 17
Maxim-CADman77
FYI, Brian have fixed this problem in version 3.2 (I've checked and confirm this):
BTW, 'Nifty Attributes' can now be loaded simultaneously with Attribute helper:
... yet 'Attribute Helper' is useless (obsolete) for actual Inventor releases.
